I was waiting for you to mention that, Here are pictures of the motor, with much help from Mike!
Another BP Swap with Rebuild
Here is are pictures of the oil cap that Mike made. Sadly we destroyed 2 good hub caps to produce it, but I think it looks awesome! The engine is becoming more original as it gets back together.
Last but not least are pictures of the work done today. I went out a bought a magnaflow muffler for $40, which after a bit of clean up should be good to go, and I sand blasted the valve cover, so it is good to go for paint now. I am really happy with how smooth the valve cover is. It is getting painted Ford Red, and the exhaust manifold is getting painted black.
the muffler looks good
did the glue in the cap dry good and hard?
Mike, AKA the sasquatch
Yep, the next morning it was super hard! I am really happy how it turned out! Thanks again for helping with, well... everything.
that one may do...
It is pretty much the same as what canadian tire sells, except canadian tire charges $145 +taxes. I figure since it is High Flow it should work.
Question, does this sound right? I measured the belt size that I need for the bp, the one that goes from the water pump to alternator to crank. I measured 33", is that the size that everyone else is using? What car do they usually come off of?
Just ask for one for an escort gt. Should be able to adjust the slack out of it.-Greg
Redneck Engineer
FOTY - '09
ok, I just wanted to get one that would be tight so the alternator doesn't get too close to the firewall
Auto Bp Help
I wanted to verify with the other auto bp festiva's out there. Has anyone put a bp engine with an auto festiva tranny? Did you use a manual escort throttlebody and a manual escort ecm?
Will the under dash harness of a 1989 EFI harness connect with the 1993 engine harness?
Not sure on that one, but I have a 89' so I can check for you tomorrow if I remember.Originally posted by timmay89 View PostWill the under dash harness of a 1989 EFI harness connect with the 1993 engine harness?-93' L BP swap/e-series, coilovers, RIO front swap, redrilled festy drums, Miata 14" 7 spokes.
-85' Nissan Sentra 5 spd.
