Another BP Swap with Rebuild
  • #76
    I was waiting for you to mention that, Here are pictures of the motor, with much help from Mike!
    • #77
      Here is are pictures of the oil cap that Mike made. Sadly we destroyed 2 good hub caps to produce it, but I think it looks awesome! The engine is becoming more original as it gets back together.
      • #78
        Last but not least are pictures of the work done today. I went out a bought a magnaflow muffler for $40, which after a bit of clean up should be good to go, and I sand blasted the valve cover, so it is good to go for paint now. I am really happy with how smooth the valve cover is. It is getting painted Ford Red, and the exhaust manifold is getting painted black.
        • #79
          the muffler looks good did the glue in the cap dry good and hard?
          Mike, AKA the sasquatch
          • #80
            Yep, the next morning it was super hard! I am really happy how it turned out! Thanks again for helping with, well... everything.
            • #81
              what kind of magnaflow is that?
              • #82
                I honestly have no clue, it's a shiny one!
                I am looking into get the following cat to go with it:
                Will this be good to get?
                • #83
                  that one may do...
                  • #84
                    It is pretty much the same as what canadian tire sells, except canadian tire charges $145 +taxes. I figure since it is High Flow it should work.
                    • #85
                      Question, does this sound right? I measured the belt size that I need for the bp, the one that goes from the water pump to alternator to crank. I measured 33", is that the size that everyone else is using? What car do they usually come off of?
                      • #86
                        Just ask for one for an escort gt. Should be able to adjust the slack out of it.
                        -Greg
                        Redneck Engineer
                        FOTY - '09
                        • #87
                          ok, I just wanted to get one that would be tight so the alternator doesn't get too close to the firewall
                          • #88
                            Auto Bp Help
                            I wanted to verify with the other auto bp festiva's out there. Has anyone put a bp engine with an auto festiva tranny? Did you use a manual escort throttlebody and a manual escort ecm?
                            • #89
                              Will the under dash harness of a 1989 EFI harness connect with the 1993 engine harness?
                              • #90
                                Not sure on that one, but I have a 89' so I can check for you tomorrow if I remember.
                                -85' Nissan Sentra 5 spd.
