Greg, you're using a B6 header, right? (at least that's what it looks like from the pic).  if so, do you have a particular reason why you didn't use the B3 header? (i'm wishing i did).
Tom's B6 Build Thread
That's what was on the motor when it came out of the parts car. I don't think it's even for a mazda. If you look it has some extra holes drilled to make it fit. Is it possible to use the b3 manifold/header? ( i haven't compared) It would make install easier, and promote torque.Originally posted by FestYboy View PostGreg, you're using a B6 header, right? (at least that's what it looks like from the pic). if so, do you have a particular reason why you didn't use the B3 header? (i'm wishing i did).Last edited by eurotiva; 02-07-2010, 10:08 AM.-Greg
Redneck Engineer
FOTY - '09
Ok thanks. it's a newer b6 where the throttle body points to the drivers side.Originally posted by muscle_Car1 View Postif its the over the valve cover(early B6) variety yeah the b3 header would work-Greg
Redneck Engineer
FOTY - '09
That's probably the reason for the extra holes drilled in the header flange. I think the header was made for the early b3/b6 exhaust bolt pattern.Originally posted by eurotiva View PostOk thanks. it's a newer b6 where the throttle body points to the drivers side.
I don't think the bigger tubes of the B6 header will hurt much, since forced induction doesn't rely as heavily on the exhaust primary tubes to aid in cylinder filling. If anything, the larger tubes may help increase flow to the turbo. They may decrease the initial gas velocity and/or reduce the boost pressure, but with the rear mount turbo so far away, the remainder of the exhaust system will be the determining factor. I would certainly wrap the tubes to keep the heat and velocity up. This is just my .02 opinion. I don't know a lot about turbocharging, and even less about rear mounted turbos............. It would be interesting to first run it with a stock B6 manifold and then switch to the header, just to see what the difference is! Keep up the excellent posting - can't wait to see the results!
I'm sure TominMO is going crazy with anticipation!Brian
I think your correct about the flange holes. And I do hope it won't matter as much. And as far as rear turbos I'm still learning and always will beOriginally posted by blkfordsedan View PostThat's probably the reason for the extra holes drilled in the header flange. I think the header was made for the early b3/b6 exhaust bolt pattern.
I do plan on running it with just the b6. Then with the turbo.-Greg
Redneck Engineer
FOTY - '09
Prediction: 16.60 @ 81 mph.Originally posted by eurotiva View Post...I do plan on running it with just the b6.Festiva: Because even my dog can build a Honda.
I would love to do a rear turbo setup on mine, but I don't think an open element air cleaner under the car would work out for me on a daily driver (not in Nebraska). I thought about putting the air cleaner housing inside the car and run a duct to the outside of the rear quarter panel. Maybe then put a small side scoop just in front of the passenger side tail light for ram air.
I have a lot of questions, so I'm glad your posting this thread!Brian
Yeah Tom sand blasted it while he was here. And the paint is "duplicolor engine enamel" and the color is "cast aluminum coat" ThanksOriginally posted by stillslow5 View PostWow, great job Greg. What did you use to paint the valve cover? Did you blast it first?
Man, it really looks great.
Good. I think that's fair. And I think turbo should be 15.5ish.Originally posted by FestivaFan View PostPrediction: 16.60 @ 81 mph.
Yea if he didn't have the spare tire well I'd put it there. I think it can be hidden in a few spots. We'll have to see where it ends up.Originally posted by blkfordsedan View PostI would love to do a rear turbo setup on mine, but I don't think an open element air cleaner under the car would work out for me on a daily driver (not in Nebraska). I thought about putting the air cleaner housing inside the car and run a duct to the outside of the rear quarter panel. Maybe then put a small side scoop just in front of the passenger side tail light for ram air.
I have a lot of questions, so I'm glad your posting this thread!-Greg
Redneck Engineer
FOTY - '09
Ok Update time again........................
After work I went to the hardware store and auto parts store to get more parts.
Got Tom some "new" axles. No remans here. Grabbed some axles seals too. Might as well replace them while I'm there.
Also the intake gasket came in, so I was able to put the intake back on. Thanks to Tom, it was already clean.
I also painted the fuel rail (it was rusty), and made the harness how it needed to be. Moved the tps plug and retaped the harness.
I also got the timing belt cover trimmed and installed. Motor mount bracket, and alternator bracket cleaned, and installed.
So here is a before and after pic of this motor. I think it looks a litttle bit better. Hopefully I'll be putting it in this week/end.
 I'll keep the updates coming.............................Note:new shiny hardware
						-Greg
Redneck Engineer
FOTY - '09
Greg, that engine looks really nice!:happy5:Dan
-Greg
Redneck Engineer
FOTY - '09
How big are those tubes?Originally posted by eurotiva View Post
Poverty produces creativity
