^ i'm not sure I'll measure them for ya.
Tom's B6 Build Thread
-Greg
Redneck Engineer
FOTY - '09
That engine does look good!!
ThanksOriginally posted by Damkid View PostThat engine does look good!!-Greg
Redneck Engineer
FOTY - '09
its looks okay93 L B6T DD http://www.fordfestiva.com/forums/sh...ad.php?t=37751
RIP_90 LuX http://www.fordfestiva.com/forums/sh...ad.php?t=32249
RIP 88 LX / B8-MEhttp://www.fordfestiva.com/forums/sh...ad.php?t=26398
RJ
It'll look like yours, but betterOriginally posted by skimsucka View Postits looks okay
 and it'll be faster....:lol:
						-Greg
Redneck Engineer
FOTY - '09
sorry for the long wait for a reply:Originally posted by eurotiva View PostThat's what was on the motor when it came out of the parts car. I don't think it's even for a mazda. If you look it has some extra holes drilled to make it fit. Is it possible to use the b3 manifold/header? ( i haven't compared) It would make install easier, and promote torque.
the B3 header has a cat flange already attached, whereas the B6 header has no flange and larger tubes. both fit first gen B6s and all B3 heads, but the extra drilling is required to fit to the second gen B6 (the one Tom has in the car). the B3 header will promote low-mid to high mid torque increase, but the B6 header is for top end only (very large runners; low gas velocity at lower RPMs). i do hope it's the B3 header, otherwise it may be prudent to add a reducer to the exhaust before the cat or resonator.Trees aren't kind to me...
Timing Belt Cover Trimming
What are the advantages and disadvantages of trimming the timing belt cover? Would it be advisable for someone who is not into racing?Originally posted by eurotiva View PostI also got the timing belt cover trimmed and installed.
My timing belt cover has expanded with heat and age so that it is daily being "trimmed" by the water pump pulley. Trimming it, as you have, would save me the expense of finding another one in better condition. But what would be lost?
I'm really enjoy watching the transformation in the appearance of the engine. What you did to the valve cover is nothing short of magic - a real thing of beauty.
John Gunn
Coronado, CAJohn Gunn
Coronado, CA
Improving anything
Originally posted by JohnGunn View PostWhat are the advantages and disadvantages of trimming the timing belt cover? Would it be advisable for someone who is not into racing?
John Gunn
Coronado, CA
I just trim them so I can see the timing belt, and water pump. Some people remove them all together. All of them eventually rub the water pump pulley. It's easy to do and lets you see if the water pump is leaking and easier to replace if needed. Thanks for the compliments.
 As far as benefits I think it's about the same with or without it, I just like something being there to keep fingers and stuff out.
						-Greg
Redneck Engineer
FOTY - '09
Personally, I prefer to have it covered all the way. Besides the occasional finger, it will keep dirt, water, etc. out of the sprockets and idler. Also, if a bolt, nut, ratchet handle or anything large ever falls into the general area and gets pulled down into the lower sprocket by the belt, it can cause all kinds of problems. With my luck, I would drop a socket down there when I have the hood up and the engine running.Originally posted by JohnGunn View PostWhat are the advantages and disadvantages of trimming the timing belt cover? Would it be advisable for someone who is not into racing?
John Gunn
Coronado, CABrian
I think what Greg did is the best of both approaches; sufficient protection and you can still see in there.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Originally posted by Flyin4stroke View PostGreg's then man no doubt.. He is in my phone as "The MAN"
That's funny Mike. Glad you got yours back up and running.
Time for an update...............
It's been unusually cold here (30s-40s) So progress has been slow. I got everything ready for installation.
Here's the oil pan Before.....
After.............
Got the lower portion of the timing cover finished and installed...............
Also got the oil feed and oil return installed......................................... ..................
More updates coming soon
						-Greg
Redneck Engineer
FOTY - '09
Poverty produces creativity
