Project Tin_Can - b8 SOHC install
  • #61
    if you pull the head you might as well swap to the dohc head
    • #62
      Nope SOHC is the way its staying for now - It looks more stock that way
      92 GL - parts car
      97 aspire - parts car
      87 323 DX - daily driver
      • #63
        Originally posted by Festiva_tunner View Post
        update:
        Ran compression test on the motor
        1,2,4 all test at 12.5 bar and 3 tests at 13 bar
        I did notice that I'm getting a backfire on one of the intake strokes so I'm thinking I have build up on an intake valve sticking
        I've got the valvetrain soaking in seafoam
        Does anyone know any other tricks aside from rebuilding the head?
        You must have had to buy a fair bit of seafoam!
        1988 Chevy Sprint Turbo 997cc
        • #64
          the only thing that didnt get seafoam was the coolant
          92 GL - parts car
          • #65
            Did you un-wrap where the stock VAF location was or did you cut/splice andrun new to the drivers side. Oneof those wires, is a shielded wire.....
            • #66
              unwrapped
              • #67
                can u even do this never read anything on it before
                the heart beat of america stops here______________/\
                \/\_____________FORD
                FOREVER
                • #68
                  Depending on which engine you have.
                  Take it back to the back porch, join the 3 string revolution.
                  • #69
                    *Pictures Update*
                    Ok so I finally go home before dark and got some as is pictures
                    Motor status:
                    I got it to fire and run yesterday - I had to keep feathering the throttle to keep it running - once it died I got nothing but sputters - I let it sit and tried it again and it would try to kick but wouldn't take - when it dies it huffs back into the intake
                    92 GL - parts car
                    • #70
                      humor me on something... pinch off or block off the valve cover breather tube that you routed to that tiny filter...
                      Jim DeAngelis
                      • #71
                        looks really nice, like the hood and grill . have you gotten new spark plugs and wires for it? if not maybe just doin a standard tune up would take care of your issue, also that breather filter might do better to just sit on the VC outlet, unless you did that for a reason..
                        91 red l-
                        • #72
                          Trevor call me when you can.
                          -Greg
                          Redneck Engineer
                          FOTY - '09
                          • #73
                            is it missing when its running?
                            • #74
                              wires and plugs are new - disty was new two mo before - the breather was interfering with the disy adjustments so the hose is temporary
                              no
                              92 GL - parts car
                              • #75
                                Trevor, block off the breather, brake booster, FPR and anything else connected to vacuum. See if it makes any difference.
                                Jim DeAngelis
