Originally posted by FB71
Project Tin_Can - b8 SOHC install
You thinking cracked manifold? A buddy and I were just talking about that
92 GL - parts car
97 aspire - parts car
87 323 DX - daily driver
*** update ***
So festyboy helped me get the thing running
The good news is it now runs after going through the electricals
The bad news is it has a rod knocking now so it still sits
92 GL - parts car
Turbo it with a 100-shot just to see what it'll do at the drags; blow it up; then stick in another B8.Originally posted by Festiva_tunner View PostSo festyboy helped me get the thing running
What was the problem that kept it from running?Originally posted by Festiva_tunner View PostSo festyboy helped me get the thing running
I don't suppose you had any sort of warranty with the engine?'93 Blue 5spd 230K(down for clutch and overall maintanence)
We did a lot of checking fuel and ignition and pump and intake finally we let it dry out adjusted timming and tried with all the b3 stuff then one by one started adding the b8 stuff
I may rebuild I may replace
92 GL - parts car
Hey Trevor, did you see this?
http://www.kyboutlet.com/vaf/product...=80&model=155190 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
problems found: timing off two teeth, dizzy rotor off 120*, plugs came out compleatly wet, bottom end knock once fired. needs rebuild.Trees aren't kind to me...
Checked out a rebuild cost and its more than the cost of the motor so not sure yet
92 GL - parts car
Go to a yard and buy a b8 it'll be cheaper IMO. Even if it's a day drive.-Greg
Redneck Engineer
FOTY - '09
Originally posted by eurotiva View PostGo to a yard and buy a b8 it'll be cheaper IMO. Even if it's a day drive.
I would have to find a day to go because there are no B8's near me
92 GL - parts car
might be able to relay a block to you....Trees aren't kind to me...
Sounds good give me a call to work out the detailsOriginally posted by FestYboy View Postmight be able to relay a block to you....
92 GL - parts car
Poverty produces creativity
