M3NTALS B6T Build Thread pics always
  • Originally posted by M3NTAL View Post
    I've decided that I'm going to ditch the AC. I have other vehicles that have AC.
    I'm not sure how I'm going to route the bypass line yet Charlie it it does look like it will need to be done.
    THATS NOT A STREET CAR ANYMOAR
    91GL BP/F3A with boost
    • ^true, I win by default but he's still never run any of his setups (trying to motivate)
      -Greg
      Redneck Engineer
      FOTY - '09
      • I'm ready Greg & Mike for roll racing. Sounds like we need to get a 3
        Way go pro video going!!!
        My buddy just tuned my car last night on 18psi IAT's are a little high like 130-140 (75ambiant) because of no inter cooler. And I have no idea where the timing is at because I forgot to put the lower timing cover on this motor lol
        plugs don't have aluminum on them so who cares! (Still junkyard motor) the 460's are at 70% duty cycle and were at 10.5 AF ratio (we ran it a little rich because no IC causing high IAT) and from
        6500-7000 I'm like 9.0 AFR
        Go pros and turbo cars sounds like a fun night
        -M3NTAL MARK! Woo!!
        • Time slips don't lie, and street racing is illegal.
          Timing is everything on tuning, so good luck with that guesswork.
          Quite being a puss and go run your car if it's so fast.
          I'm sure if you have think you had a remote chance of beating me you would have already come up here and tried to race me
          -Greg
          Redneck Engineer
          FOTY - '09
          • yeah timing is everything we added 2 degrees last night on the highway and the plugs look good and no dentonation ( I know that just cause you can't hear it doesn't mean it's there ) but the plugs look ok.
            Who knows, this motor might just last me longer than 6 months lol.but I'm sure those ring lands won't like 18psi for very long as they weren't designed to take that much boost.
            Street racing is illegal but so it marijuana but i still smoke it occasionally.
            -M3NTAL MARK! Woo!!
            • Don't be surprised then when 2 bp's show up ready to be killed. Bp killer!
              How is a 1.6l on 18lbs ever going to beat a 1.8l on 20lbs....
              Bp killer! How many bp's you killed lately. Like recently. Like within the last few months or yrs.
              That's classic. Go get us some more dyno runs in second.
              1989 Ford Mustang GT 5.slow
              1996 Ford F-150
              • Idk how a 1.6L would be able to kill a BPT1.8L on 20lbs...never claimed it would.
                What I did say was we all should roll race with our GoPros. I think that would be a sweet video. I think your blowing this out of proportion...it's actually pretty funny
                Roll race me and find out if your that curious..
                I don't care if I lose...it's not like I've ever claimed to be the fastset I'm not that competitive.
                -M3NTAL MARK! Woo!!
                • easy boys easy
                  Never Hire a Boy to do a Man's Job!!
                  • Ahh I thought we were just messing around 😝
                    Don't start no stuff won't be no stuff
                    1996 Ford F-150
                      Your sig states otherwise, when and where?
                      -Greg
                      Redneck Engineer
                      FOTY - '09
                      • Does it...? Does it say Fastest anything in my sig?
                        pretty sure it doesn't banana time
                        Anytime after 10pm tonight is good for me.
                        -M3NTAL MARK! Woo!!
                          Rings should still be fine at 18psi I was running 22-25 on my b6d block with a crap tune. Found out after I tore it down I bent a rod though.
                          Better Than Nothing Racing
                          Way too many cars
                          :woc:
                          • Here's a article that I found about Dynoing in 3rd vs 4th for what it's worth Mike if you want to educate yourself
                            Your vehicle can be tested in one gear, or in all of its gears. Theoretically, the results should be the same regardless of what gear is used because the increased torque in the lower gears is cancelled by the decreased speeds. In the real world, there are always differences between the gears, and the differences can be explained by a number of factors. Because of nasty things like friction and inertia, different gears always have different amounts of drag, and the greater the reduction or increase in the gearbox, the greater the drag. A low gear may fly the engine through the rpm range so quickly that it never has a chance to build up any helpful intake and exhaust resonance that those header engineers spend so much time trying to achieve. Fifth gear may be spinning your drivetrain so quickly that significant increases in gearbox drag are created. Third and fourth gears are usually favorites for finding your actual horsepower, and testing all of the gears is a useful method for discovering problems in your drivetrain. Many dynamometer operators go right for the gear that is the closest to a 1:1 ratio as it has the lowest drag in the gearbox and therefore the highest horsepower reading (usually) on a vehicle that is properly sized to be tested on this dyno. Of course, many cars don't have true 1:1 gear ratios, and many cars are not the exact proper size that the dyno was designed for, so blindly going for the gear ratio that is closest to 1:1 is not always the right answer. My dyno is sized for vehicles that are around 3000 - 3500 lb. A significantly lighter vehicle, even though it may have the same horsepower as a larger vehicle, will probably have a final gear ratio that is higher. Therefore it will seem to struggle a lot more than a heavier car. In such cases, the lower gears, like third, may give the highest horsepower reading.
                            What I've read everywhere it that torque numbers will be slightly lower in 3rd than 4th but hp numbers are usually 1% off from 3-4th gear.
                            -M3NTAL MARK! Woo!!
                            • Go dyno it again. Either gear and report back, should be making more power.
                              Gotta have proof somewhere, or people are going to start calling BS
                              I'm just trying to motivate you to do something with your car.
                              Also you can't believe everything you read. Third is about 20%off . I've been around this stuff a lot longer than you know of.
                              I can go prove how bad third is. my dyno guy said we could do third and it would show way over 300HP...I almost did it to brag with, but I'm honest about things and don't mind walking the walk after talking the talk
                              -Greg
                              Redneck Engineer
                              FOTY - '09
                              • Last time I read or post in this thread too.....
                                -Greg
                                Redneck Engineer
                                FOTY - '09
