what are you doing for spark? COP?
I need to figure out how to wire my COP's in. Anyone know of a write up for the festy harness specifically>?
M3NTALS B6T Build Thread pics always
It looks like your intake manifold could use an ultra slick Rocketman Rocketblock®©™ idle valve delete plate!
Ok exhaust is done 3" down pipe with a 3" exhaust and a straight thru muffler. I also wrapped the downpipe with exhaust wrap.
Inter cooler mounts are painted and IC is set
And the piping is all welded and set.
We chopped the stock festiva outlet and flipped it upside down...
...Ran to napa and eyeballed a hose that looked like it would work...
(Don't mind the other rad hose on the right..that was the old setup)Last edited by M3NTAL; 10-22-2013, 09:12 PM.
Top mount interheaters make my brain hurt.
Mark, that fox body is wayyyy too nice. Those cars were intended for thrashing, not to look pretty! haha, It is nice to see a pretty one now and again though.
Sweet! Thanks Mark! I gotta ditch the TMIC on the MS3. Heeeeeat soak : /
Heres a link to the same one i got, i got this one off CL for 40 bucks
thanks zanzer
My friend Mario has a shop around me, so hes helping me with the fabrication.... hes a fabricator and loves doing roll cages, wheelie bars and parachute mounts.
Heres a fox he built for a guy in PA. Single turbo on megasquirt 3, CCWs, Crank trigger, LS Coils, 16psi made 807hp 835tq they are tuning it now on the rollers so theres a little more left in it.
Mike bring your FOX down and lets put a turbo on it!
He put a Borg warner 80mm on his 06' Duramax so now its sequential turbo'd Its so nasty! it sounds like a god damn plane taking off lol makes 600hp 1200tq on 40psi
Thank you for not putting the IC piping under the rad support/sway bar like your first setup :p looks much cleaner that way
looking good Mark! I have been playing around with my gt2554 as well. Coolant bypass fits past it pretty good, unlike the 28r.
