Daniel's TruckStiva Build Thread (56k warning)
Seems like the easiest way to go. But Daniel said he kidded the axle, I wanna know what that's all about!
Hatch my friend, I'm just making my wheel base wider to accommodate
edit, it was $50.Originally posted by Nerd Racing View PostI paid $60 for mine and it's in better shape
Thing only had 60k on it and was pulled from a bus that had a cracked manifold. The new manifold came with a new turbo.
True but I look at it as flywheel HP, so after drivetrain loss etc it'd work out closer to 7hp per 1lb/min
I'm curious what ya'll are doing to mod the axles, I'm assuming you mean somehow shorten them to the width of the festiva? Because the protege G axles are too wide. I'd love to be able to somehow mod a pass side escort/protege axle to work in a festiva, so I can use the escort halfshaft with the BP instead of having to mod up the Capri shaft to it.Originally posted by daniel_cogar View Postgot the final axle last week and modified it and the drive train is complete....went to the jy today and got a set of shift cables from a Hyundai elantra, snagged the shifter as well and modified the ends a little bit and it shifts now through all gears and is very tight, the elantra shifter seems shorter, so I now have a short shifter lol.
lol :nono:Originally posted by Nerd Racing View PostI paid $60 for mine and it's in better shape
its the 8 blade...... "The 8blade hx35 has a 56mm compressor inducer. This is found on 1995-1998 cummins manual pickups. The compressor flows 52 lb/min according to the compressor map."Originally posted by Damkid View PostI'm jealous of that turbo
I figured that there really isn't much info on Holset turbos on here. I came across on the dsmtuners and found some really good info on mostly all of the popular Holset turbos. HX35: The 8blade hx35 has a 56mm compressor inducer. This is found on 1995-1998 cummins manual pickups. The...
you wouldn't believe what I payed lol
Originally posted by Nerd Racing View Postdang it quit copying me!
lol i'm not I've got it all in my head i'm just slower at getting the parts lol. That trans mount was all my idea then I seen urs and figured you thought I copied ya lmao. ....MINES a TRUCK nananana
