Dr Dan's B6 build
  • Vid on start up ...... I promise!
    Gotta show this car off at Madness, Dan!
    Hmmmm ........
    Dan
    • I am at the point of turning the key on this. I bolt on the 323 exhaust downpipe...and it is hitting the axleshaft!
      The knuckle is not all the way up, where it would be be at ride height, but the pipe will still hit the axle on corners or uneven surfaces. It was hitting, so I jacked the knuckle up some to get it to bolt on, but when I tightened the bolts, it hit the axle again.
      Looks like I will have to "massage" the downpipe some, to get more clearance. 1/8-1/4 inch more clearance should do it.
      I needed a 30 mm socket too. The new axle nuts are bigger than the old ones. I used a 1 1/8 socket on the old ones, but it didnt fit the new ones. I only had a 1 1/8 socket and 1 1/4 socket. Store didnt have a 30mm, but a 1 3/16 socket fit quite nicely.
      Dan
      • Wow Doc, I can't understand the downpipe hitting the axle. I just looked at mine and it goes under the axle with an inch and a half to spare. I wonder what's different. I have the original exhaust manifold from the '89 323 that the engine came from and the '89 Maxda 323 downpipe that I ordered from Rockauto. It bolts right up to the cat like it came from the factory that way. From your pictures I think we have the exact same manifold so it must be the downpipe. Sorry you are having troubles. Wish I could look at it in person. Sux to be so close and yet so far!
        • Its all good Zoe.
          Fixed!!!
          Check it out now
          Before,
          and this was with the knuckle jacked up a little, When I let off the jack, to use it to help "massage" the pipe, the axle pushed the pipe down about 1/8. lol
          Now
          ...and how I did it
          I first put the jack under the pipe where the straight section starts to bend, for support, so as not to put stress on the weld on the exhaust manifold side of the pipe, and the manifold itself as well.
          Then I stuck a piece of fence railing in the cat end of the pipe
          Then I crawled up under there and pulled down on the fence railing pipe
          and presto!
          About 5/16 clearance with the knuckle all the way down
          I dont know why mine hit the axle. Maybe it was made on a monday morning, after a good, "I cant remember what I did", weekend!
          Dan
          • These pics aren't great, but thats how my car is. The last one is how I modified the idle up solenoids to my Weber.
            • Yea, I dont have an idle up solenoid on my Weber. It didnt come with one.
              Prolly add one at a later date.
              Dan
              • The old downpipe bender trick! Glad it worked for ya! Sorry about my pictures, they're kind of huge. I need to learn how to message Tinypix! lol. I want to hear that thing run! Good luck.
                • It's the idle up stuff off of the Festy. Works OK.
                  • freakin awesome work nice clean carb setup you have enjoyed reading though till this point post a video when she runs!
                    RJ
                    • Vid when it happens.
                      Just cored the cat. :p
                      Hmmm...cored the cat....that dont sound quite right!
                      Dan
                      • Originally posted by drddan View Post
                        Rreeereereeeer!
                        • sure is pretty!!
                          core a kitty??
                          should run like a kitty on a hot tin roof!!
                          • I have a vid!
                            ......I dont know how to post it! :cry_smile:
                            Dan
                            • lol, upload to youtube or photobucket and post a link!
                              Youtube is better IMO, but you need an account.
                              2008 Kia Rio- new beater
                              1993 Festiva- Fiona, DD
                              1997 Aspire- Babyspire, DD
                              1994 Aspire - Project Kiazord
                              1994 Aspire- Crustyspire, RIP
                              • How's this? ...Better? :p
                                Dan
