My n/a super b3 build
  • Cannibeasty
    replied
    So any dyno runs as of yet? I'm really curious to see what the b3 is capable of N/A!
  • greywolf200
    replied
    Originally posted by drumnerd33 View Post
    Lol well yes I see that, only reason I didn't want to do the aspire swap was the lug pattern
    Sent from my LG-LS970 using Tapatalk 4
    X2
  • greywolf200
    replied
    Originally posted by bhazard View Post
    You will find that sticking with "festiva size" tires will make the car feel a lot more peppy than a larger tire like those 14's.
    I went from a 205/50-15 to a 195/45-14 on my bpt car and I will never run the bigger stuff again.
    That is a big jump in tire size. I'm considering going to 165/50-14 next time for that reason.
  • greywolf200
    replied
    The Capri swap is cool at first....and cooler when you do the galant upgrade to them. But then you realize you can't run 13's anymore and you pretty much tripled your unsprung weight up front for brakes that aren't really any better on a festiva than aspire brakes.
    But yeah if you think Capri brakes are "massive" check out the galant upgrade for them.
    I already have a set of 14" wheels that I love and want to keep and have also been considering the Aspire transmission swap when I run across one.
  • drumnerd33
    replied
  • bhazard
    replied
    Yes. Why do you think I switched to an aspire swap?
  • drumnerd33
    replied
    Is it over kill though? Cuz even the Capri size is considered over kill
  • bhazard
    replied
    They call it the vr4 swap even though you don't use the vr4 rotors...I believe you use the 266mm rotors which I think was 10.5" vs 10.2 for the xr2. But they are WAY thicker like at least 50% thicker maybe.
    You turn down the hub ears on a lathe or grind them down, get longer studs for a b series pickup, and fit the rotor over the hub instead of behind. Then use an escort gt caliper.
    They're truly huge for the festiva. Maybe I still have pics of mine.
  • drumnerd33
    replied
    This galant swap? Is it the vr4 I think I read a little bit about it... What all does it entail?
  • drumnerd33
    replied
    Well part of that is the gearing... The larger tires make it feel like you have no power cuz it's geared wrong.... The aspire transmission will fix that problem, yes you are adding unsprung weight with larger tire/rim and larger brakes... But it's all for a purpose, larger tire/rim gives better handling, better stability at higher speeds. Bigger brakes give you better stopping power, and cooler brakes. Like I said earlier my brakes actually work fine but I smelled my brakes after hitting them hard to not miss an exit on the highway.... That's not good at all considering I hot them hard but only for like a few seconds and they got hot that quick
  • bhazard
    replied
  • bhazard
    replied
  • drumnerd33
    replied
    Exactly.... Only issue would be technically it is a good idea to turn your rotors everything you put on new pads, but in this case these brakes are massive and I plan on running slotted rotors and good pads, so these brakes will probably have at least double the lifespan of stock brakes.
  • greywolf200
    replied
    Yeah its called a captured rotor and it doesnt bother me, i have a press and a solvent tank to clean and repack the bearings so no biggy just a little bit of extra work but only needs done every now and then. Plus you get bigger brakes and keep the festiva pattern. I am also looking at doing an aspire transmission swap which people dont understand either.... its for the differential ratio, the aspire ratio matches the tire size if you are running 14s so the speedometer is correct and will make acceleration way better.
    X2 on every thing you said. How often do people change their rotors(Charlie not included)?
  • moz
    replied
    KIA Rio uses a cable f series. Heard nothing but good things about it.
    Sent from my Galaxy Nexus using Tapatalk 4
