Ian's B6T Festiva build
  • fastivaca
    replied
    A little bit of progress to report...
    - new gas tank installed
    - replaced the main filler tube and the evap "stuff" with much better condition items
    - Walbro 225lph fuel pump installed
    Too bad all of this is stuff no-one will see!
    Old filler tube on the left, replacement on the right:
    Gas tank all prepped for install:
  • Advancedynamix
    replied
    Does it smell like maple syrup? Hehe.
    It will be nice to know your fuel system is minty fresh. Fuel issues kill more turbocharged engines than all other issues combined. I've seen guys blow 3 engines before realizing they had rust and junk in the tank that was clogging the screen at full flow.
  • fastivaca
    replied
    As I posted in another thread I discovered that my gas tank had developed a leak. Ordered a new one from Rockauto and it arrived today...
    A big plus for me personally is that it's made in Canada!!
    Came with new gasket and screws to mount the fuel pump bracket too! Will be installing this tank along with the new Walbro pump setup in the next few days. Also plan to treat it with some protective finish like Line-X or an undercoating material.
    Ian
  • fastivaca
    replied
    Originally posted by Advancedynamix View Post
    Tip: replace that short line with Gates green shield high pressure fuel hose. It's resistant to ethanol, so newer fuels won't break it down. You never know what people throw in those kits, and melted rubber and swollen lines are no fun.
    Duly noted... thank you sir.
    Ian
  • Advancedynamix
    replied
  • 350freak
    replied
    awesome build keep it up I'll find me another festy or the parts to fix mine one day.
  • fastivaca
    replied
    More goodies arrived today!
    Decided to go with the Walbro GSS342 that will be mounted to an Aspire fuel pump bracket.
    Ian
  • Advancedynamix
    replied
    Looking good!
  • fastivaca
    replied
    Package arrived this afternoon...
  • fastivaca
    replied
    Flywheel ready to go....
  • Advancedynamix
    replied
    Originally posted by fastivaca View Post
    Is there a difference between the Festiva and Aspire pump brackets?
    Ian
    Yeah, the aspire uses a short section of fuel line and I think the Festiva pump interfaces with an o-ring and one of those clip deals. The aspire unit is easier to mount an aftermarket pump to, but you'll have to swap the plug to use it. I did that on tweak. The 89 auto unit is like an aspire, but has different connectors than both the later F.I. Festiva and Aspire. The 89 unit uses a bigger pump, like a Capri XR2 pump.
    Aspire 4 door parts wont work in a Festy, you'll need the 2 door parts. That's all I think I know about that stuff and I may be wrong because you're in Canada so your cars are a bit different in many areas. Also, I haven't had the pump out of a 93 Festy in several years, so I may be confused.
  • fastivaca
    replied
    They are pretty universal. I used a GSS342 on Tweak, but that was with an Aspire pump bracket.
    Ian
  • fastivaca
    replied
    Ball is starting to roll!
    Ordered a Spec Stage 2 clutch along with SuperPro sway bar to body bushings and LCA to body bushings. I decided to go with the stock weight flywheel so I had that resurfaced this week. Going to clean up the garage this weekend. Once that's done I have some work to do on my daughter's Festiva... wheel bearings and shocks/struts all four corners along with new speakers in the doors.
    When I've finished her car then I can start work in earnest on the B6T!! Hoping to have the engine swap done by the end of March and the body done by the end of May.
    Ian
  • Advancedynamix
    replied
  • fastivaca
    replied
    Originally posted by kumalaba View Post
    keep up the good work! get you a good fuel pump & a rocketman ecu if your planning to up the boost. mine works great @ 15 psi
    Thanks Danny. Forgot about the fuel pump. I've heard Walbro 255lph but for which car?
    Rocketman ECU I have.
