For starters the exhoust strap has been upgraded to wire!! And second off I understand conserns and adding input and insight on how to do it acording to you and others in the past, but with lifting its been done one time before but never with a bp motor so knoladge on this is verrry little which you haven't givin any on the lift which other then critisism.... you guys have been great with tips on every thang else And I appreaciate that a lot so if you have any ideas that would be better/safer ide appreacieate it greatly
Only thang I've hurd that I could have done different but not necessary is that I should have placed the front blocks under the strut I agree but dissagre because the way I did it made my car 3" wider and for off road which is essential you have to agree with that
The other thang was the control arms, only negatives and no input on ideas but ill add side bracing on the extended part just for the extra strength
Any thang else I'm missing??? If not stay off the roads till I take it through my off road course at my farm
matching tires will be a fue weeks $700 for the ones I'm wanting, yes its a little rusty but is a nebraska car appraides $250 to get fixed
