'89 Festiva build...
Thanks! And yes, I've found that tool online, but fail to see how it's worth $180. If it comes to it though, I'm going to have to buy it.Originally posted by avitsefdrof View Post
Sent from my iPhone using Tapatalk1990 Flat black Festiva...Mostly stock...
Dead photo link fixed above.Originally posted by Zman86 View PostThe parts gathering continues...
Back from the blasters, have to install the RS backing plate, press out the rear axle bushings the it's all off to powdercoating on Thursday. Blasters didn't do a great job and charged what I thought was an excessive amount, but I needed it done and know not to go back to them.
Also ordered everything I couldn't get through our parts supplier at work today. New lower control arms/ball joints, a set of Hawk front brake pads, Motocraft rear brake shoes, rear wheel cylinders and a drum brake hardware kit.
Not a c clamp, a ball joint press. The one shown is ideal for the work described above, but I couldn't recommend it for certain actual ball joints. I've seen to many of those bend/spread under the load.Trees aren't kind to me...
For sure! You found rear axle bushings yet? If not, I found these on eBay. Look to be the same.Originally posted by bravekozak View PostThat's one hell of a big C-clamp!
I don't have one like that.
I also need to change my rear bushings.
I may have to visit you in the spring.
I am certain that I have something that you need.
Sent from my iPhone using TapatalkLast edited by Zman86; 12-21-2017, 07:35 AM.1990 Flat black Festiva...Mostly stock...
I'm down!Originally posted by bravekozak View PostMini meet. I work in Mr. & Mississauga.
Got some more stuff done at lunch today on the Festiva, drilled out the axle and backing plate holes to accept the larger 7/16" grade 8 bolts required to run the rear camber/toe adjustment plates.
Pressed the old studs out of the spindles and tapped them for the new bolts.
My Canadian Tire 7/16"-20 tap didn't like whatever the spindles are made of. Had to order a professional-grade tap for tomorrow as the threads were not cut deep enough to allow the bolts to thread in.
Pressed in the new axle bushings. While not exactly the same as the old ones, they fit snug and should do the job.
