That adapter may not work on a b6t. I'm pretty sure the b6t throttle body has a different tps orientation than this engine. I haven't looked into microsquirt at all but I'd highly recommend this setup for someone new to MS with a 90+ efi festy. Other than the wideband wiring everything it needs is in the factory harness. And pretty much any b series can be run on the factory wiring.
something something.... DANGER ZONE!
Abs plastic sheet same as front. No the rear panels are a PITA to do lol.Last edited by shorestiva; 10-05-2017, 05:05 AM.Better Than Nothing Racing
Way too many cars
:woc:
Thanks!
Pic dump from Madness/Tail of the Dragon trip last weekend.
20171005_221238 by Joseph King, on Flickr
20171006_143814 by Joseph King, on Flickr
20171006_145338 by Joseph King, on Flickr
20171009_085159 by Joseph King, on Flickr
20171009_104441 by Joseph King, on Flickr
20171009_114905 by Joseph King, on Flickr
20171009_115108 by Joseph King, on Flickr
20171009_121655 by Joseph King, on Flickr
20171009_121914 by Joseph King, on Flickr
20171009_123937 by Joseph King, on Flickr
20171009_123949 by Joseph King, on Flickr
20171009_124344 by Joseph King, on Flickr
20171009_125642 by Joseph King, on Flickr
20171009_192829 by Joseph King, on Flickr
Way too many cars
:woc:
This build is really coming along! I wish I had access to an alignment rack to set the rear camber, I don't even have a reliably flat piece of concrete to accurately set my toe lmao.
It was really cool seeing your plastic interior panels in person at madness, I think I might do that too soon-ish.Dark blue '91 B6t + E series
Something new breaks every day
If you get one of these self levelling lasers you can do it yourself. I set boards so they are all level first, then park the car on it and adjust till they are level with the cars weight.Originally posted by Eviljimchicken View PostThis build is really coming along! I wish I had access to an alignment rack to set the rear camber, I don't even have a reliably flat piece of concrete to accurately set my toe lmao.
Peel and stick tiles are my thinnest shims, just pieces of stacked plywood and melamine is what i use for the thicker ones. I believe my LR side is like 2 inches of shims and the RF is the 1mm or whatever tile
Thanks it's getting there lol. I still have a bunch of things that bug me to fix. The rack is nice but it's almost the same amount of work as doing it on the ground. It's just a little easier to take measurements.Originally posted by Eviljimchicken View PostThis build is really coming along! I wish I had access to an alignment rack to set the rear camber, I don't even have a reliably flat piece of concrete to accurately set my toe lmao.
The interior panels definitely clean up the interior. The rears are a real pain to make though. Start with making a cardboard one of the passenger side. It's a lot easier to work with and your going to be doing a lot of cutting and trimming to get it right. Once you get the cardboard one to fit the way you want trace that onto your plastic and cut it out. Once you're done with the passenger side you can take your cardboard version from the passenger side and trim it to fit the drivers. My plastic came sandwiched with cardboard that was the exact same size as my plastic sheets so I used that for the template. Made it pretty easy to lay everything out.
Youwere the one looking for a b6t to compare harnesses with right? (sorry terrible at remembering names/screen names)Last edited by shorestiva; 10-18-2017, 09:26 PM.Better Than Nothing Racing
Way too many cars
:woc:
Pic dump since I've been lazy about updating this thread.
New wheels and tires.
Finally mounted my afr gauge.
Took it to a track day finally.
Had some rubbing issues.
First session on the second day ended up going off in the first corner when my brake assist went out. Mounting bracket ripped off the booster hardline.
Survived the weekend packed up and headed home.
Temp were starting to get hot on track. Think I found the problem.
Flushed it every other day for two weeks and got it looking better.
Haven't done much else other than try to sort the tune out.Better Than Nothing Racing
Way too many cars
:woc:
Yep that was me! Thanks for the advice on making those panels.Originally posted by shorestiva View PostThanks it's getting there lol. I still have a bunch of things that bug me to fix. The rack is nice but it's almost the same amount of work as doing it on the ground. It's just a little easier to take measurements.
Youwere the one looking for a b6t to compare harnesses with right? (sorry terrible at remembering names/screen names)Dark blue '91 B6t + E series
175/55r13. I had vibration issues with them but it may have been the wheels not the tires.Originally posted by Zman86 View PostLove the Enkei's!
Quick question, what tire size were you running in this pic?
Sent from my SCH-I545 using TapatalkBetter Than Nothing Racing
Way too many cars
:woc:
