something something.... DANGER ZONE!
  • #61
    Are you running this on stock electronics?
    • #62
      yup
      Better Than Nothing Racing
      Way too many cars
      :woc:
      • #63
        Drove it some more last night. It seems to only run lean over half throttle. It pulls great up to the limiter if you don't go wot.
        Way too many cars
        :woc:
        • #64
          Got the data logger working tonight. If you look at the log at 5600 rpm my vaf is reading .44v and afr is 17:1. When I reached in the vaf and pushed the door as wide open as it'd go it'd max out at .33v. When it's completely closed it's only at like 3.5v so not really sure what's going on there. I hooked up a fuel pressure gauge and test drove it. It's staying around 40 psi whole way to redline.
          Way too many cars
          :woc:
          • #65
            Haven't really figured out the running lean part yet but I harassed charlie and have a few things to try to fix that. Went to put the festiva rear beam and brakes back in yesterday. Luckily I test fit my wheels on my drums before I pulled the aspire stuff off because the festiva hub center bore is to big to fit my wheels. :violent1: So I just said screw it and kept the aspire beam on there. I did at least remove the sway bar from it though.
            Way too many cars
            :woc:
            • #66
              Swapped back to the original injectors and played with the spring in the vaf today. Adjusted it something like 15 "clicks" leaner but I've got it idling at 14 and at wot near redline its at 10. Its still weird though if you back off on the throttle it will go richer. It runs way better like this though, doesn't sound as raspy and pulls hard whole way to limiter.
              Way too many cars
              :woc:
              • #67
                That's interesting. Do you have a wideband?
                • #68
                  Yeah old lm1 wideband/datalogger. Wouldn't even try to attempt all this parts switching/adjusting without one.
                  Way too many cars
                  :woc:
                  • #69
                    Originally posted by william View Post
                    If you find a exhaust that makes the b6d sound good let me know mine sounds like a Kazoo And all the 1.6 miatas at the track did to the other day. Lol
                    I've got 2 resonators and a dynomax muffler under pedro and it sounds deep with no rasp. My cores are rattling now in my resonators though, so it rattles at idle. Gotta cut them apart to fix that.
                    • #70
                      Deep with resonators? Can you post a exhaust vid? what resonators are you using the only experience I've had with them is they add a air putting sound like a riced d series Honda my buddy with a 06 colbalt ss did a muffler swap to an apexi n1 but now he's gotta drop the res to lose the Honda sound
                      Sent from my XT1585 using Tapatalk
                      Festiver
                      93 L find/5 speed
                      BP/g15mr swapped
                      Aspire brake swapped
                      stripped and sold due to rust
                      89 festie
                      rustful
                      93 festie
                      advanced suspension
                      kai/skeeter camber
                      b3t/g15mr
                      • #71
                        Resonators remove harmonics by absorbing certain Hz and also allows the exhaust gasses to expand and cool which also changes the tone. I suspect the resonators that you are used to hearing are not resonators but rather mufflers or cored resonators and cheap ones at that. Have that cobalt SS swap in a real resonator or cherry bomb and I guarantee the rasp will disappear.
                        • #72
                          I couldn't find a stainless resonator with 2in inlet and outlet so I just have two magnaflow mufflers on mine.
                          Way too many cars
                          :woc:
                          • #73
                            No real updates on the festiva. Just spent all my money on my saab again. I did finally pass all my master tech certifications this week. So I should be getting around a $10/hr raise in the next week or 2. I'm now a world class certified gm technican.
                            Way too many cars
                            :woc:
                            • #74
                              Good, now you can help me with 2 swaps...
                              • #75
                                Congratulations! I know you've been working hard at that.
