As long as its a gm or mazda swap I can fumble my way through lol.
Thanks! Its been around 2.5yrs since I started on it. Would've had it last month if I hadn't failed the hvac and auto trans certs. disgust
Finally got around to welding a tip on the muffler today. The exhaust ended behind the bumper so it made it sound a lot louder inside than it really was. Now its super quiet can barely even hear it while cruising. Still sounds like a f****ing honda though.
20161016_094658 by Joseph King, on Flickr
20161016_094710 by Joseph King, on Flickr
Cleaned up the engine bay a little. Finally mounted the vics solenoid on the firewall and taped up the wiring harness where I cut it open.
20161016_101348 by Joseph King, on Flickr
Messed around with the alignment. Its a royal pita to do with just washers.
Might have a little too much camber..... stance makes her dance lol
20161016_115432 by Joseph King, on Flickr
20161016_151754 by Joseph King, on Flickr
Thats better. I know it's not perfect but its better than what I had. Doesn't rub over bumps now but will rub through corners at speed. I should probably just go ahead and gut the back. Might help a little.
20161016_175359 by Joseph King, on Flickr
20161016_183623 by Joseph King, on Flickr
20161016_183654 by Joseph King, on Flickr
20161016_183637 by Joseph King, on Flickr
Also tried a bp01 (1.8 sohc) ecu in it today. Didn't help ran even leaner on b3 injectors.
20161016_094710 by Joseph King, on FlickrCleaned up the engine bay a little. Finally mounted the vics solenoid on the firewall and taped up the wiring harness where I cut it open.
20161016_101348 by Joseph King, on FlickrMessed around with the alignment. Its a royal pita to do with just washers.
20161016_151754 by Joseph King, on FlickrThats better. I know it's not perfect but its better than what I had. Doesn't rub over bumps now but will rub through corners at speed. I should probably just go ahead and gut the back. Might help a little.
20161016_183637 by Joseph King, on FlickrAlso tried a bp01 (1.8 sohc) ecu in it today. Didn't help ran even leaner on b3 injectors.
