That's a possibility. It doesn't hurt to try, if you have one.
something something.... DANGER ZONE!
Is this engine pulling hard all the way to redline?Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
Especially where this one has a properly tuned intake manifold. The capri b6d is tuned just like a Festiva (TQ curve) but this engine is a different animal. I've got a BP ecm I'm not using right now, if you want to try. I'll mail it to you Joe.Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
Originally posted by Advancedynamix View PostEspecially where this one has a properly tuned intake manifold. The capri b6d is tuned just like a Festiva (TQ curve) but this engine is a different animal. I've got a BP ecm I'm not using right now, if you want to try. I'll mail it to you Joe.
b3 ecu/injectors/vaf
b8 ecu/injectors/vaf
bp ecu/injectors/vaf
my money is on the BP stuff
You should run the injector that matches the ECM, or maybe slightly larger, but not more than 2lb/hr. On this engine I'd say a BP ecu may work better. The Capri b6d doesn't pull hard to redline, it drops off at about 5800rpm like the b3 does. TQ peak is around 5500rpm. This engine may have different cam profiles and the intake/exhaust manifolds are much different than the Capri. It needs more fuel up top. The BP ecm fuel map is probably more suitable. Even better yet, would be the b5 dohc ecm (not a US engine either) as it was very similar to this engine.Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
Originally posted by Advancedynamix View PostYou should run the injector that matches the ECM, or maybe slightly larger, but not more than 2lb/hr. On this engine I'd say a BP ecu may work better. The Capri b6d doesn't pull hard to redline, it drops off at about 5800rpm like the b3 does. TQ peak is around 5500rpm. This engine may have different cam profiles and the intake/exhaust manifolds are much different than the Capri. It needs more fuel up top. The BP ecm fuel map is probably more suitable. Even better yet, would be the b5 dohc ecm (not a US engine either) as it was very similar to this engine.
BP might work best. I have bp stuff im going to try on mine if i decide go to n/a
btw does anyone know if the sohc 16 valve exhaust manifold will fit a b6d? having trouble locating an exhaust manifold might force me to go turbo;
Had the back end step out on me tonight. Carried too much speed into a corner panicked and touched the brakes mid corner. Straightened up almost immediately though. Really need to get signed up for some track days so I can learn the limits of this thing.
In other news. My spare injectors are back from getting cleaned.
Better Than Nothing Racing
Way too many cars
:woc:
