Lucifer gets new Turbo setup!
  • Im still not setup the way i should be on lucifer tho. I need to finish the build before i give up. I still need to install the water meth kit. I can still go to a real exhaust. Once the build is done i will look at switching it up if it still stinks.
    19?? 150$ burnout car SOLD
    1991 (STRESS RELIEF)SOLD
    • Advancedynamix thanks for the help tho. I will get there some day!
      • You're welcome. I'm not trying to stifle your progress, you know I'll give any advice I have regardless of what direction you go in, but I just want to be clear on what a valuable baseline that a stock b6t provides. Get that big turbo to run right and put it on a load bearing dyno so we have a graph to look at.
        • Does anyone have a dyno graph with a vj14 on a festiva? id like to see.
          • This was 160ft.lbs and 161 HP at 12 .3 psi. Stock b6t ecu, water meth, automatic cams and 9:1 pistons.
            Here you can see that the TQ dips were caused by rich spots. We later found out that this was from the water methanol jet being too rich. I ordered a smaller jet and this smoothed out. I'm not sure where the other graph is though.
            • Guys the deals have been made! Lucifer will be going BPT soon. I am buying the car that was posted on facebook. I will swap that cars motor and everything over to my car. My motor will be swapped into the white car and taken back to stock stuff (vj14 normal exhaust rocketchip) and then will be sold as a running b6t rust free in need of paint.
              So pumped right now!!!!
              • Lol good for you mike.
                Tommy
                WannaBimmer Build in Progress:
                http://www.fordfestiva.com/forums/sh...-Festiva-Build
                • Trans went boom. I was going 70 normal as can be and all of a sudden I'm in 1st gear. Now thats all i have. Wtf I think that a pin came out and the fork jumped to 1st or something like that. Either way. Trans is coming out tonight.
                  • Dude, I'm glad you're okay. That could be treturous.
                    • Originally posted by Advancedynamix View Post
                      The harness kit did its job. Boy it was a lot of force! Felt like i hit a wall at 75
                      • Better yank that thing apart an see what happened!
                        You got me worried now lol
                        • And inspect your rod bearings. That kind of a rapid over rev will stretch rod bolts and toast the bearings.
                          • The trans will be on the ground tonight! I hope to have a new one back in it this weekend if i can. Ill be pulling the trans apart to see what the hek is wrong. i hope its a simple fix.
                            O well tho. I will be getting the other car in a few long weeks. It has a spare trans with it. So im covered either way. I hate that my car breaks when im going easy on it. Makes me think i should go all out all the time...
                            • I figured it out, the o2 bung is in a different orientation, (and it's not cracked).
                                yah... thats a really nice smooth tq delivery. Id like to compare this to Mentals b6t graph with the t25 turbo. I know there area tonne of miata t25 dyno sheets but id like to just try compare apples to apples.
