Are you going to reinforce the lower support any? It's really flimsy stock and is where all the TQ goes to push the car around.
Lucifer gets new Turbo setup!
Yes i need to. I can do it now. Just cant find a good write up on it. I have seen it before tho. Could someone link me please1990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
19?? 150$ burnout car SOLD
1991 (STRESS RELIEF)SOLD
Now that i have the car all apart and have seen what it all looks like down there ill understand the pictures better now. Just need to find them.1990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
Last edited by Advancedynamix; 07-19-2016, 04:32 PM.Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
I got some decent square tube from my neighbor today for free. I will use it as well as some 3" x 3" 1/4" angle from lowes. The angle will be like 30$. I would have bought it today but i forgot my wallet. A 4' stick should be enough to span the front of the car! I think.
Got the g series off the old motor. Got the stock flywheel and backing plate off. Got the G series backing plate cleaned and on. Got the g series flywheel cleaned and on. Tomorrow i need to find the TQ spec on the bolts and get to work. Also tomorrow im gonna get some oven cleaner and clean the trans before i open it up to do the Stig swap i mean top gear i mean 5th gear swap!1990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
Is a longer 5th gear going to cause more or less torque at the same speed at wotOriginally posted by mikemounlio View PostI got some decent square tube from my neighbor today for free. I will use it as well as some 3" x 3" 1/4" angle from lowes. The angle will be like 30$. I would have bought it today but i forgot my wallet. A 4' stick should be enough to span the front of the car! I think.
I would think less. It's dropping rpm giving more top speed
Sent from my SM-N910V using Tapatalk1990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
You loose torque multiplication with a longer gear regardless of torque peak rpm.Originally posted by bhearts View PostIs a longer 5th gear going to cause more or less torque at the same speed at wot
Sent from my SM-G900V using TapatalkTrees aren't kind to me...
I found some 2 x 2. Plus my neighbor gave me some nice square tube. I'll come up with something. I have the plate to and will make the base plate as the pictures show. The rest will be kinda different but the same basic concept1990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
Just adds resistance to twisting. It also helps support the bumper cover like the factory support does. The last picture is of our LeMons car. I made that support from 1/8" wall and the front support piece actually goes all the way under the angle iron. It is 1/8" thick as well. That provides a total thickness of 1/4". The original support that I made fir Tweak was made from 1/4 thick angle.Originally posted by Fecomatter View PostI haven't see these pictures of the support with the reinforcement on the front of the support as well. Care to explain?Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
I stopped in at lowes to see if they had a better tool for cutting think steel then what i have now. I have been using a small 3" angle grinder. My compressor is by far big enough but the little grinder is just to small and doesnt have the power behind it. It was a cheapie unit.
So last night i picked up a new AC 4.5" angle grinder and found a new diamond tip metal blade. It was like 15$ itself. Im so glad i bought it. It cuts right throught the 1/4 steel i bought like nothing. Id say it cuts as fast or faster then a really nice blade on a good band saw.
So i laid out my plate to the picture in the Advancedynamix post from another thread. I had both plates cut out in minutes. It was easliy 20x faster then my old method. Tonight i hope to get time to get out in the garage and weld on the plates. That might have to wait till Saturday tho. Might meet up with another member to swap parts. He has some miata brake upgrades for me and i have a set of rims for him.1990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
So zero progress on Lucifer this weekend. The wife was away for the 1st time in years so we took the weekend to hang out. Ill get back on the car tomorrow tho. We went to the autocross today. It was a blast and has me in the mood to finish up my build and get it out there.
i hope to start welding on the car tomorrow. Ill try to get my 1/4 plate cut at work tomorrow if the shop guys get time. If not ill have to do it at home. Either way ill have it ready to weld tomorrow.1990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
