I finally got to spend some time in the garage last night.
My exhaust is well under way. I will be remaking it after madness tho. This being my 1st attempt means it might work but it looks like junk. I will get a good working exhaust to get me through madness and a few little projects after Lucifer. Once i have a few projects out of the way i will remake the exhaust.
My future plan is to use a manual cutout. I want the manual cutout so i can still run my hater pipe out of the fender and still have a normal exhaust when i need some quite time. It should workout pretty good. Ill go with manual and have the knob mounted to the dash. Might do a funny sticker around the knob or something stupid. I cant wait for that but 1st i need a bit more practice with my welder.
Gonna buy a ton of scrap exhaust pipe and just weld weld weld.
Last night i have to cut the relief hole for the wastegate. I then welded my ugly elbow to the plate in the correct orientation. Tonight i have make some clearance to allow for the mounting bolts to clear. I also have to cut the elbow to allow the pipe for the wastegate to tie back into it. I dont think ill have time to get any more then that done tho. Looks like ill have to finish the exhaust up on friday.
