Festiver build thread
  • Widebody is a bit further along definitely not done though
    Sent from my XT1585 using Tapatalk
    Festiver
    93 L find/5 speed
    BP/g15mr swapped
    Aspire brake swapped
    stripped and sold due to rust
    89 festie
    rustful
    93 festie
    advanced suspension
    kai/skeeter camber
    b3t/g15mr
    • Originally posted by Festiver View Post
      Would welding washers change the sway bars tension?
      Yes. It could also cause the sway bar to crack or snap. Welding on spring steel is highly discouraged. Ryal did that as a temporary fix, but no longer uses that setup.
      • Originally posted by Advancedynamix View Post
        I thought so I don't think my sway bar is shifting but I'll definitely check it out better safe than sorry
        Festiver
        93 L find/5 speed
        BP/g15mr swapped
        89 festie
        rustful
        93 festie
        advanced suspension
        kai/skeeter camber
        b3t/g15mr
        • Check your inner control arm bushings. I've had them fail many times. Check to make sure that the arm is still centered on the bushing.
          • I never understood why people liked wide body cars so much. Like when I see "widebody everything" im just like what in the world. Not trying to insult just wondering why people like widebody and why you would go out of your way to do this. is it for looks/style or what?
            92 Festiva L - bp & hydro g, advanced coilovers, aspire brake swapped
            • Originally posted by fudge View Post
              Just for looks. My brother had a honda crx that was a foot and a half wider than stock. Looked pretty good actually from 100yds away or so, lol.
              • What is your secret to the added girth in such a short time? What are you putting on it?
                • I like it!! Do you remember what year of Expedition that rack came from?
                    My impulse buy of my 16x8.5 no offset wheels is the reason of me needing to flair as my fenders and tires were in a constant war the coilover made the suspension soft again so I needed to make some body adjustments
                    Festiver
                    93 L find/5 speed
                    BP/g15mr swapped
                    89 festie
                    rustful
                    93 festie
                    advanced suspension
                    kai/skeeter camber
                    b3t/g15mr
                      Oh that's a good point I'll definitely check that
                      Eh not entirely for looks but yes I did want to add some aggression to the body as well, I like it tho
                      I cut along the top ridge of the body line I didn't want to completely destroy the cars lines like most wide bodies after the top was cut I did a slash down to the wheel arch I arched the fenders around the tires (went a lil too far) then patched in with sheet metal
                      Festiver
                      93 L find/5 speed
                      BP/g15mr swapped
                      89 festie
                      rustful
                      93 festie
                      advanced suspension
                      kai/skeeter camber
                      b3t/g15mr
                      • Originally posted by buzzsaw View Post
                        Thanks! 04 is one of the years of that gen it requires alot of trimming lol but free is for me
                        Festiver
                        93 L find/5 speed
                        BP/g15mr swapped
                        89 festie
                        rustful
                        93 festie
                        advanced suspension
                        kai/skeeter camber
                        b3t/g15mr
                        • Photo update and god I love cd-5s
                          Festiver
                          93 L find/5 speed
                          BP/g15mr swapped
                          89 festie
                          rustful
                          93 festie
                          advanced suspension
                          kai/skeeter camber
                          b3t/g15mr
                          • So I adjusted my camber more got my driver side to -4° and tried bringing my passenger side down from -5.6° to -4° but when I tightened everything and put the car down it was still -5.6° so I'll have to try again but my torque steer (which was terrible before) is non existent now pulls in a perfect straight line so much that it feels very slow unless you watch the speedometer
                            Festiver
                            93 L find/5 speed
                            BP/g15mr swapped
                            89 festie
                            rustful
                            93 festie
                            advanced suspension
                            kai/skeeter camber
                            b3t/g15mr
                            • Check it again after driving around. It sounds like you nailed it. Maybe the car wasn't settled when you checked it. The E brake can do funny things to the chassis when you lift and lower it.
                                I did check it again and it is spot on 4.92 degrees both sides damn good guess when I just pulled on the wheel and retighten it lol
                                So I had a race against a 400hp 7.3 and we were perfectly even so now that the car pulls straight it's time for more HP
                                so I have a big cone filter on an intake and a good exhaust system
                                So I'm going for bang for buck but I don't want to do anything riggy and I don't have 2500 for a good turbo setup I'm thinking some cam work is the exhintake swap worth it? Or just get a set of cams and go to a quality regrind shop? What would you guys suggest for lift overlap and duration I'm looking around I'll report here with anything I find but picking brains is usually pretty fast for info
                                Festiver
                                93 L find/5 speed
                                BP/g15mr swapped
                                89 festie
                                rustful
                                93 festie
                                advanced suspension
                                kai/skeeter camber
                                b3t/g15mr
