Festiver build thread
  • #16
    Bought a xr2 shaft to bp adapter really need to get a mill i couldve made it but hey it was only $55 for a guaranteed fit and grade 8 bolts this weekend I'll be sending out my mounts to be modded for a bp xr2 trans swap forward mounting 2.5" forward still debating on a turbo setup if I do from what I researched the pc3 will work as a fmu being it just interrupts. And modifys the ECU's signal to the injectors, tps and, rpm I have a t25 laying around I can throw in and just have fun (without pushing it I love festiver too much to blow it up on purpose) so many things to debate on what to do
    Sent from my XT1585 using Tapatalk
    Festiver
    93 L find/5 speed
    BP/g15mr swapped
    Aspire brake swapped
    stripped and sold due to rust
    89 festie
    rustful
    93 festie
    advanced suspension
    kai/skeeter camber
    b3t/g15mr
    • #17
      So bp is in and running I'm still looking for a manual throttle body (if anyone has or knows where to get one in need asap) but I kinda rigged the b3 tb to work the engine runs super ugly wiring I'm gonna go back and clean it all up now that it's working but I get the engine in and started super happy and excited (my first engine swap or really anything big mechanical wise) and my clutch won't release now it was the original festiva clutch it's just what I had thatd work so I gotta pull the engine back out now to see what's wrong I might just swap my g series in now just need the axles and a clutch I want to get a spec stage one bp clutch and I'm gonna make my own mounts now I built my self confidence up more I feel ok making my own trans mounts with a 2.5" forward mounting
      Festiver
      93 L find/5 speed
      BP/g15mr swapped
      89 festie
      rustful
      93 festie
      advanced suspension
      kai/skeeter camber
      b3t/g15mr
      • #18
        Festiver
        93 L find/5 speed
        BP/g15mr swapped
        89 festie
        rustful
        93 festie
        advanced suspension
        kai/skeeter camber
        b3t/g15mr
        • #19
          So festiver is still down 3 weeks later I really miss her driving a full size 89 Sierra doesn't make and driving enjoyable it's just different anyway I've given my attempts at making trans mounts the engine mount is done but ugly but the trans I just can't seem to do im gonna buy mounts from shadetree itll just be so much better 1 I can trust them and 2 they'll be much more attractive than anything I would do fab work just isn't my thing also my rad fan seems to be a problem it's too thick so I found a 2.6" thick high performance fan on Amazon which will probably work better too
          Festiver
          93 L find/5 speed
          BP/g15mr swapped
          89 festie
          rustful
          93 festie
          advanced suspension
          kai/skeeter camber
          b3t/g15mr
          • #20
            Bp/g is finally mounted thanks dad for the help I'm overly happy and excited with what was done today this is my first engine swap and it's finally back on track now it's just time to button things up I know my build is common and actually very easy in the world of engine swaps but I can finally say I drive a truely modified car + bp power so next weekend I'm gonna pick up the summer festiva from shadetree and down payment for bp/g mounts I want a set just because mine are ugly and once winter comes I got plans for festiver
            Festiver
            93 L find/5 speed
            BP/g15mr swapped
            89 festie
            rustful
            93 festie
            advanced suspension
            kai/skeeter camber
            b3t/g15mr
            • #21
              I now have a running driving 1.8 bp/g festiva whole lot faster than stock and I didn't go past 1/2 throttle main part I love is not having to downshift for every hill main issue starter is shot, the oil cooler is leaking antifreeze badly and I need intake manifold gaskets it's not leaking badly but it is leaking
              Festiver
              93 L find/5 speed
              BP/g15mr swapped
              89 festie
              rustful
              93 festie
              advanced suspension
              kai/skeeter camber
              b3t/g15mr
              • #22
                Ok update festiver blew a brand new cv axle c clip didn't seat as it don't think the manufacturer didn't slot the spline also needs a new water pump front main seal and a starter but it's getting there
                Festiver
                93 L find/5 speed
                BP/g15mr swapped
                89 festie
                rustful
                93 festie
                advanced suspension
                kai/skeeter camber
                b3t/g15mr
                • #23
                  I'm sure you'll have lots of fun running around with a swapped festiva. Good Job!
                  What size wheel/tires you rolling on?
                  • #24
                    Haha yeah got to drive it a bit before the axle blew apart it's a whole different car and xxr 537s 16x8 +0 with nitto neogens 205/45r16 im lowered about 4" and it rubs pretty bad at lock I dont regret it buying them because I love the look but in reality they don't fit lol I just can't turn too far besides that it's fine
                    Festiver
                    93 L find/5 speed
                    BP/g15mr swapped
                    89 festie
                    rustful
                    93 festie
                    advanced suspension
                    kai/skeeter camber
                    b3t/g15mr
                    • #25
                      The wheel/tire combo does give it a mean, aggressive look. I really like it.
                      • #26
                        update pic why bother putting the front end back together if I'm not done right?
                        Festiver
                        93 L find/5 speed
                        BP/g15mr swapped
                        89 festie
                        rustful
                        93 festie
                        advanced suspension
                        kai/skeeter camber
                        b3t/g15mr
                        • #27
                          Thanks a ton man it pokes about an inch from the fenders
                          Originally posted by Festiver View Post
                          I'll def look into it I have some business in Tennessee so I'll try to plan it all for one trip
                          Festiver
                          93 L find/5 speed
                          BP/g15mr swapped
                          89 festie
                          rustful
                          93 festie
                          advanced suspension
                          kai/skeeter camber
                          b3t/g15mr
                          • #28
                            What did you end up going with for wheels?
                            • #29
                              These will be my summer wheels xxr 537 16x8 +0 as I have a set of 13s for winter I have snowflakes for my other festiva
                              Festiver
                              93 L find/5 speed
                              BP/g15mr swapped
                              89 festie
                              rustful
                              93 festie
                              advanced suspension
                              kai/skeeter camber
                              b3t/g15mr
                              • #30
                                pulled the engine back out to do the starter
                                Water pump
                                Timing belt
                                Oil pan gasket
                                Fix up some coolant lines
                                Oil pan was a nightmare I love Mazda but this was terrible
                                Deleted alot of the stuff on the intake manifold and painted it
                                Got the engine back in with another passenger axle via shadetree thanks a ton runs alot better and no leaks! A first for me lol still having idle problems but I don't have a air leak hmm engine seems to prefer the disty twisted all the way clockwise and doesn't care where the tps is adjusted to maybe I gotta adjust my vaf? Someone help please I can get it to sit at 1200 but if you rev itll sit at 2500 for 30 seconds than go back down to 1200 maybe it's my lack of exhaust? Either way I'm happy with my car so far
                                Festiver
                                93 L find/5 speed
                                BP/g15mr swapped
                                89 festie
                                rustful
                                93 festie
                                advanced suspension
                                kai/skeeter camber
                                b3t/g15mr
