Festiver build thread
  • Oh and
    plug in the new engine
    test and tune
    Figure out what's up with my reverse lights
    Festiver
    93 L find/5 speed
    BP/g15mr swapped
    Aspire brake swapped
    stripped and sold due to rust
    89 festie
    rustful
    93 festie
    advanced suspension
    kai/skeeter camber
    b3t/g15mr
    • what kind of exhaust manifold is that
      • Originally posted by Festiver View Post
        Nvm rereading a few more times I understand what you're saying with the micing but where in the xr2 manual?
        Sent from my XT1585 using Tapatalk
        It should have a distance in the specification chart or somewhere in clutch replacement. All my service manuals are packed so I can't tell you exactly where.
        You can use a depth mic, or even a vernier caliper with depth, and a straight edge.
        • Originally posted by festyfreak39 View Post
          The question I get asked most lol on my original bp which was from a 94 protege lx it seemed to be stock had the Mazda heat Shield and all but it has no markings or anything
          Festiver
          93 L find/5 speed
          BP/g15mr swapped
          89 festie
          rustful
          93 festie
          advanced suspension
          kai/skeeter camber
          b3t/g15mr
            Oh ok thank you
            Festiver
            93 L find/5 speed
            BP/g15mr swapped
            89 festie
            rustful
            93 festie
            advanced suspension
            kai/skeeter camber
            b3t/g15mr
            • So from what I see on here performance wise it seems like my old bp was down on power....very down like 50-60hp as b3s are pulling better lol also it's been so cold here 15 with a -10 windchill I've been pretty lazy and haven't done anything so hopefully Sunday ill go out and finish my mounts
              Festiver
              93 L find/5 speed
              BP/g15mr swapped
              89 festie
              rustful
              93 festie
              advanced suspension
              kai/skeeter camber
              b3t/g15mr
              • FINALLY A REAL UPDATE
                So I finally finished my engine mounts much better this time much happier with my work and not embarrassed of my craftsmanship
                Festiver
                93 L find/5 speed
                BP/g15mr swapped
                89 festie
                rustful
                93 festie
                advanced suspension
                kai/skeeter camber
                b3t/g15mr
                • Let's see em!
                    Oh also I remember you telling me to disconnect the Iac one thing I realized is we have winter over here does the iac raise the engine rpm in the cold weather like below zero or the the ecu go off the coolant temp sensor
                    Festiver
                    93 L find/5 speed
                    BP/g15mr swapped
                    89 festie
                    rustful
                    93 festie
                    advanced suspension
                    kai/skeeter camber
                    b3t/g15mr
                    • The IAC is a thermal reactive air bleed system with stepper motor assist. It's like having a coolant thermostat with computer control. Disconnecting it will lock out the ECU control, so idle stability may suffer.
                      • Yeah, I disconnect the ECM control and leave the coolant hoses hooked up. The reason is that the electronic part seems to go haywire on the b6d/t management systems. It may not be that way on the BP though.
                          Went a bit over my head with that description lol but that's sounds to be what I'm looking for to have a higher cold start idle
                          Festiver
                          93 L find/5 speed
                          BP/g15mr swapped
                          89 festie
                          rustful
                          93 festie
                          advanced suspension
                          kai/skeeter camber
                          b3t/g15mr
                            I'll just give it a try
                            Festiver
                            93 L find/5 speed
                            BP/g15mr swapped
                            89 festie
                            rustful
                            93 festie
                            advanced suspension
                            kai/skeeter camber
                            b3t/g15mr
                            • Festiver build thread
                              Originally posted by william View Post
                              Let's see em!
                              Pics I took that night
                              Festiver
                              93 L find/5 speed
                              BP/g15mr swapped
                              89 festie
                              rustful
                              93 festie
                              advanced suspension
                              kai/skeeter camber
                              b3t/g15mr
                              • FESTIVER LIVES
                                got the engine all plumbed and wired up
                                bunch of turning over and no start big puddle of oil
                                I panic looking all over for leak source
                                Wow I'm a dumb I forgot to put the new oil filter on....
                                anyway new filter on still didn't start my 3k mile injectors are seized closed... what a shocker lol so I would like to unseize them but I throw my 200k mile injectors in and it fired almost right up needs some tuning but ran and stayed alive had to go shopping so I didn't get to play much Tonight but tomorrow I'll try to get her dialed in oh and I have a short shifter coming in tomorrow
                                Festiver
                                93 L find/5 speed
                                BP/g15mr swapped
                                89 festie
                                rustful
                                93 festie
                                advanced suspension
                                kai/skeeter camber
                                b3t/g15mr
