Festiver build thread
  • Originally posted by william View Post
    Because the hole spacing is to wide on the vw struts. It won't bolt to the festiva knuckle if it's not sloted up.
    As for washer just one that fits.
    Looks like your using festiva struts so yeah they'll bolt up problem is the damping is weak and you can't get much camber out of them before the knuckles hit the strut. Maybe 1.5 degree
    Sent from my SAMSUNG-SM-G900A using Tapatalk
    Oh, sorry, i didnt realize the ones you were using had different hole spacing.
    • I picked up washers to space the bearing and the hats and tomorrow and Tuesday I can slot the holes in a mill at my school
      Sent from my XT1585 using Tapatalk
      Festiver
      93 L find/5 speed
      BP/g15mr swapped
      Aspire brake swapped
      stripped and sold due to rust
      89 festie
      rustful
      93 festie
      advanced suspension
      kai/skeeter camber
      b3t/g15mr
      • Bath time! Really need to do something about those door dents
        Festiver
        93 L find/5 speed
        BP/g15mr swapped
        89 festie
        rustful
        93 festie
        advanced suspension
        kai/skeeter camber
        b3t/g15mr
        • How the hell does that thing pass inspection?!?
            Rooood lol whatcha mean my tires? I have a set of inspection steelies
            Festiver
            93 L find/5 speed
            BP/g15mr swapped
            89 festie
            rustful
            93 festie
            advanced suspension
            kai/skeeter camber
            b3t/g15mr
            • my exhaust hits the rear beam now that I lowered the rear more I'm gonna end up doing a U over the beam
              Festiver
              93 L find/5 speed
              BP/g15mr swapped
              89 festie
              rustful
              93 festie
              advanced suspension
              kai/skeeter camber
              b3t/g15mr
              • Are you considering putting the aspire spindles on the festy beam now that you have coilovers and can properly set up the suspension?
                Dark blue '91 B6t + E series
                Something new breaks every day
                • Originally posted by Eviljimchicken View Post
                  I'm just gonna run my coils with the aspire beam I don't have my old festie beam I might keep the beam on ømëgá tho
                  Festiver
                  93 L find/5 speed
                  BP/g15mr swapped
                  89 festie
                  rustful
                  93 festie
                  advanced suspension
                  kai/skeeter camber
                  b3t/g15mr
                  • So I put my coils in and wide bodied the front a bit like 2" so I can keep it soft the girlfriend is very happy that it's not my cut springs that sound like a train crash over every bump
                    The Bondo work is far from finished but pa spring time hit half way through so it's been pouring all week once I finish the front the rear will follow suit then I'll have a wide body festiva
                    Festiver
                    93 L find/5 speed
                    BP/g15mr swapped
                    89 festie
                    rustful
                    93 festie
                    advanced suspension
                    kai/skeeter camber
                    b3t/g15mr
                    • Does anyone know how to stiffen the steering a bit more it turns so easily too easily lol
                      Festiver
                      93 L find/5 speed
                      BP/g15mr swapped
                      89 festie
                      rustful
                      93 festie
                      advanced suspension
                      kai/skeeter camber
                      b3t/g15mr
                      • We should all be so Blessed! Congratulations!
                        No car too fast !
                        • Originally posted by Festiver View Post
                          Check your toe measurement, a toe out condition tends to make it feel like it's easier to turn off center.
                            Spent alot of time making sure my toe is perfect but I'll check again
                            Festiver
                            93 L find/5 speed
                            BP/g15mr swapped
                            89 festie
                            rustful
                            93 festie
                            advanced suspension
                            kai/skeeter camber
                            b3t/g15mr
                            • Originally posted by Dragonhealer View Post
                              Hey thanks
                              Festiver
                              93 L find/5 speed
                              BP/g15mr swapped
                              89 festie
                              rustful
                              93 festie
                              advanced suspension
                              kai/skeeter camber
                              b3t/g15mr
                              • Ok to start my toe is perfect my suspension is all tight and snug everything seems perfect besides driving
                                So I'm having trouble
                                she sometimes wonders on the road like will randomly shoot to the right or left a little
                                she will turn hard left beautifully but turning right I need to turn way farther than it feels I should and it doesn't feel as tight
                                The wheel doesn't come all the way back straight by itself
                                Accelerating pulls to the right slightly but decelerating pulls to the left
                                All these problems point to a bad alignment but my camber and toe are great and caster is unadjustable so how could it be off really need help here I'm out of ideas
                                Festiver
                                93 L find/5 speed
                                BP/g15mr swapped
                                89 festie
                                rustful
                                93 festie
                                advanced suspension
                                kai/skeeter camber
                                b3t/g15mr
