OverKILL!
  • #91
    I didn't take the plate up to the bumper mounts. I didn't have enough plate on hand. I just went with the way I did lucifer.
    I have been talking lots of pictures. I'll do a good write up once all done.
    19?? 150$ burnout car SOLD
    1991 (STRESS RELIEF)SOLD
    • #92
      I thought it was just me. Every time I have done something to help the handling or grip of my car it makes it feel slower lol.
      G series moved forward eliminated torque steer and wheel spin it won't hardly spin them in the rain with the e it pulled hard to the right when I got on it and would spin till 3rd.
      Sent from my SAMSUNG-SM-G900A using Tapatalk
      • #93
        William the core support will do a lot for the handling. At least it seems to have helped me. Car does what I want it to do in turn now.
        • #94
          Lower core support is done
          • #95
            Not just you. They feel really slow and boring, even with 180ftlbs of TQ. But, that's a good thing. Isn't it great when a Festiva with 3 times the factory TQ hooks up better than it did when it was stock? Lol. It's like a cheat code.
            • #96
              I think my overly fat tires and 0 camber take away that unlimited grip effect in any weather I can get wheel spin on demand I can bump the clutch in 2nd and rotate the car without moving lol I need some camber and skinnier tires
              Sent from my XT1585 using Tapatalk
              Festiver
              93 L find/5 speed
              BP/g15mr swapped
              Aspire brake swapped
              stripped and sold due to rust
              89 festie
              rustful
              93 festie
              advanced suspension
              kai/skeeter camber
              b3t/g15mr
              • #97
                Yup. You'll also notice a big difference in how easy there car is to steer. Spring rate and dampening make a world of difference too.
                • #98
                  after i go for a little test drive the front end is coming back off to get some paint on it. I have my fingers crossed that the torque steer is little to none! The motor looks solid in the car when driving. We will see tonight tho...
                  • #99
                    What's your toe and camber set at? Alignment is very important.
                    • Originally posted by Advancedynamix View Post
                      I have no clue. I know i need to adjust some tho. It has a slight pull to the left. o nand off throttle it stay straight for the most part.
                      Torque steer is gone! it still has some left to right pull when it brakes lose and grabs again tho. All in al its pulling very hard and all the way to the limit. I was able to boost in 2nd around a big corner. Before i would wait till well past the corner before even trying it. Now Its nothing. Planted firm but soft.
                      I would say its pulling along side sport bikes for sure.
                      • I might have to go to a stiffer spring in the front. Last night during the test drive i did hear tires rubbing. I have not heard that yet in this car! But i was doing 100+ on a hilly road... will test more before i buy new springs tho. The core support has helped the handling. The car is stiff and goes where i point it.
                        • Get shorter tires those 13's are tall you have on there and your springs are most of the way down. Preloaded springs is like having stiffer rates. Glad to hear it pulls stright now
                          • Originally posted by william View Post
                            Ill be setting it up a bit better this weekend! gonna see how dialed in i can get it.
                            • William you will have to come drive it again! The difference is crazy.
                              • Yes! I definitely want to.
