I went to PaP and got the intake rocker shaft assembly, $10+tax, grabbed the PCV as well, will pick up a new one later. I'll throw it on after the sun goes down, jumping in the shower now, I smell so bad the dog can't stand me. Porch thermometer says 115F (that's 46C to you Canucks) it only goes to 120F.
Forum Charity Project - Feisty the Festy in Oklahoma
Installed the new shaft, tick is gone. Still some smoke, but only put the used PCV on, maybe residual oil from before as well. Gonna put it up on stands tomorrow, the exhaust needs work, put my hand over tailpipe, no pressure, lotsa holes I think.1963 Fairlane - future NSS drag car
Not to tell Larry what to do.
If the head doesn't need replaced.
I be happy to put the money to be spent on shipping the head toward exhaust components.
My guess is a mid-pipe and muffler would go a long way toward fixing that.
I'll let Larry advise us as to what the path is forward.'93 Blue 5spd 230K(down for clutch and overall maintanence)
I'm getting ready to go outside to put it up on jackstands to see what the dealio is on the exhaust. She said the mechanic told her the muffler and converter would need replaced. He put a.straight pipe in in place of the.converter, then put the converter back in. She spent 2k with the guy and he had it 2 months.1963 Fairlane - future NSS drag car
The muffler is shot, found this new Walker muffler on eBayMotors for $41 shipped.
The resonator is rusted out at the seam and where it connects at the rear pipe. I'm considering cutting it out and just welding in a pipe.
I haven't taken the converter off, the mechanic said it would need replaced. The exhaust does seem choked. I found this Magnaflow cat on eBayMotors for $96 shipped. We no longer have inspections in Oklahoma. I could possibly go from downpipe to behind the resonator with just a piece of pipe.
I also haven't checked with Festfull to see if he has a system on one of his parts cars.1963 Fairlane - future NSS drag car
Food for thought.
If the cat is clogged, likely from the manlfuctioning PVC valve, can it be burned off?
Carbon will burn in air at 600°C.
This might be too hot for the catalyist support, which could melt.
If this is an OEM cat it was, at one time worth $80 or at a scrap metal yard.
Which could help pay for needed hardware and/or piping from the down pipe back if you wanted to delete the cat due to no inspections.'93 Blue 5spd 230K(down for clutch and overall maintanence)
It is the factory cat. I had one blow up on me years ago, ('89 Isuzu Pup) pellet type, blew glowing bb's all over the highway.1963 Fairlane - future NSS drag car
If you suspect the cat and you have no inspection then you could just break the platinum out of it. That way you can still pass a visual inspection (if they do that in your state). This worked very well on my Mustang (total of 6 cats!) and it really liked the reduced restriction
If they don't do a visual then that thing is worth some coin and could buy you a new muffler along with other odds and ends needed
The OEM Festiva cat support is a different type ceramic support.Originally posted by Larry Hampton View PostIt is the factory cat. I had one blow up on me years ago, ('89 Isuzu Pup) pellet type, blew glowing bb's all over the highway.
More like a very narrow but long grid array in a monolithic block.
Can clog, but very unlikey to fall apart.'93 Blue 5spd 230K(down for clutch and overall maintanence)
No I know, its the honeycomb design, Ford's superior offering to GM's inferior pellet type back in the day. I think everyone has gone to a honeycomb, less likely to clog, higher flowing.1963 Fairlane - future NSS drag car
if the car dosent need inspected run a straight pipe back to a new muffler, sell the cat like john suggested & your done! MARK you can use my $ to purchase the new muffler if you havent used it to buy parts with already. tks dannyNever Hire a Boy to do a Man's Job!!
depending on what type of sound is livable for the owner....getting rid of the cat and no resonator will make it rumble pretty good inside. I would put a resonator and muffler on it. You can get them (mufflers) cheaper at the mcparts stores. Hows the money or parts situation going...I can send some money or may have extra parts...let me know."FLTG4LIFE" @FINALLEVEL , "PBH"
I dunno, PAP has the exhaust I think on the one Festy they have, but I'm scared what they'll ask for the cat. I got overheated today about 1pm. I've been drinking lots of water and Gatorade, had a headache ever since, rapped a few times, basically felt like crap. Hopefully feel better in the morning.1963 Fairlane - future NSS drag car
I've already bought the parts, no biggy though because I can use them on Mabel. She's gonna need a full rebuild so between the stuff I picked up for the head and the bottom end stuff I already had stuck back to build a B3 for my 93 (changing to a B6D now), I'll have everything needed for that project.Originally posted by kumalaba View Postif the car dosent need inspected run a straight pipe back to a new muffler, sell the cat like john suggested & your done! MARK you can use my $ to purchase the new muffler if you havent used it to buy parts with already. tks danny
Advance has a Walker for $28. I've used their stuff before and have had good service from them. It's listed as a universal and an exact fit. So I'm guessing it's an exact fit when you purchase the correct size reducers LOLOriginally posted by GenevaDirt View Postdepending on what type of sound is livable for the owner....getting rid of the cat and no resonator will make it rumble pretty good inside. I would put a resonator and muffler on it. You can get them (mufflers) cheaper at the mcparts stores. Hows the money or parts situation going...I can send some money or may have extra parts...let me know.
We've got $150 to use. Just trying to figure out the best way to get it to Larry since he doesn't use PayPal. I think it would be cheaper for him to buy the parts locally instead of me buying them and then shipping them to him because my discount would be eaten up by the shipping cost.
Depending on what everyone wants to do, I can either refund everyones $$ and we can start over, or I can possibly mail him a cashiers check for the amount. You guys just let me know what you wanna do :thumbup:
Sounds like you may have her all fixed up.
