Also wanted to add that SEPHIAS have that G series transmission but are an escort sized car. You can probably get that trans and use the smaller rio axles and make that work as well.
Kia Rio and what we know.
Originally posted by kellen302 View Postcould be conflicting info, but this site shows a 3.9 final drive http://www.automobile-catalog.com/auta_details1.php
This is where I got my info from.
Latest news, reviews and advice on buying a car, saving gas, electric vehicles, tires and more. Visit Toronto Star Autos for news and trends in vehicles.
There's another site that lists the same 4.17:1 gearFestiva: Because even my dog can build a Honda.
Originally posted by kellen302 View PostI bet the overseas models got the 3.9 final drive
In 2003 they went back to the 4.17, but the transmission got a higher 4th and 5th gear, almost exactly like the '90 to '94 323 and Protege (0.91:1 and 0.73:1).
This combo is almost exactly like the 323 F-series transmission. Also, this means that 2001-02 Rio 5 speeds can have a 5th gear swap.
When they went to Hyundai parts (which we can't use) in 2006, the transmissions went the other way and the gearing was increased, with even more gear than the 2001 Rio.
I'm shopping for a 2002 trans.Festiva: Because even my dog can build a Honda.
I found an 02 Rio Transmission :O
While I was in there, I was looking at the front hubs, they look pretty close, but I haven't tried them, the hole for ABS is the only thing noticably different, as far as it actually bolting up.. we'll have to wait until someone tries it I suppose.Last edited by zoom zoom; 12-28-2011, 03:27 PM.2008 Kia Rio- new beater
1993 Festiva- Fiona, DD
1997 Aspire- Babyspire, DD
1994 Aspire - Project Kiazord
1994 Aspire- Crustyspire, RIP
As for different year Rio gearing, this may help:
Early Rios had the 1.5 engine with 96 hp, while the 2003 and later model years got the 1.6 engine with 105 hp.
That may be why the final drives were changed from 4:17 to 3:90; to make use of the larger engine's greater torque and hp.
Just a guess.
I went to the JY yesterday and snapped a few pics, I believe the INT wiper switch will swap, i'm willing to try it and maybe sell it if I get it to work since I've got the 626 switch.
Here's a link to the photobucket acct with random pics.. I WILL be buying the transmission and seeing what I can do about mating it to a BP this week, the question is, will an Mfactory differential for a G series transmission bolt in?
I may even end up attempting to swap THAT cluster into my aspire, I know it won't work in a festy, but I need a RPM tach and that's perfect..
pics here of the transmission/steering knuckle/cluster/rear suspension
this is an EARLY 02, the struts and springs are on my Aspire right now..........
Originally posted by JPT View PostIt looks like Kia decided that they needed to lower the highway RPM on the Rio, because in 2002 the car got a 3.90:1 final drive.
ratios with a higher number like 4.56 ??
call me bigfoot I guessReflex paint by Langeman...Lifted...Tow Rig
Originally posted by Movin View PostI slot the upper hole of the strut at the knuckle mount,
its easier for me that way, but I used VW golf struts
for that well known German quality...
Want some negative camber on my shortened aspire springs...rusEfi - DIY ECU
93 EFI: tach cluster, aspire mirrors & spindles. ZX2 master cylinder, BP+G25 swap with a door hinge, rio struts. 205/50r15, 140mph speedometer,rear disk brakes, mini cooper + subaru front brakes rear sway bar
Guys, what about kia rio cross member? Would it by any change mount a G trans to our innocent Festiva bodies without fabrication? I know I am daydreamingrusEfi - DIY ECU
Russian asked:
"Guys, what about kia rio cross member?"
I doubt the crossmember will fit, but I'm wondering about the manual steering rack.
And the crossmember won't fit but the g series mounts on a Rio are way simple to adapt to the festiva xmember .New build on the way .
