In open loop cold start you hve the pressure lower to burn a little bit less your overall tanks would be better. If you use 5-10 percent less fuel at WOT thats some more savings albeit flooring it is bad for mileage unless you couple it with some nicely timed glides, which does work well. Another possibility is a voltage offset to the ecu provided by a lm1 or similar wideband with that feature. The fpr anf a wideband and a mpg cam...500 bones, a lot of cost but rewards would come over time.
MPGs run, Aspire SE
Originally posted by Zanzer View PostIf you were referring to the other post then we were only looking for pulses to verify the ECU and spout signal was not dead and my method worked just fine, don't knock it till ya try it :pTrees aren't kind to me...
Ahhhhhhhhhhh. Hehehehe, OK I also wondered if that may have been what you were alluding to as well. Sorry but my ESP license doesn't kick in until next week LOL :mrgreen:
You needs to PM a brotha!Last edited by Zanzer; 08-22-2013, 06:54 AM.
Originally posted by FestYboy View Postrunning the FPR is going to smooth things out and should NOT be installed last (last should be the header). i would START with the FPR, that way it's there to support the cam and header as they are installed.2008 Kia Rio- new beater
1993 Festiva- Fiona, DD
1997 Aspire- Babyspire, DD
1994 Aspire - Project Kiazord
1994 Aspire- Crustyspire, RIP
I had a good talk with Matt today, and based on that, I will do the following:
1. Install the FPR, and run it at stock pressure. (No need for another test here.)
2. Install the cam, and test it at stock fuel pressure. Advance ignition timing a bit, maybe 3 degrees.*
3. Do a test at reduced fuel pressure (~27 at idle, ~35 at WOT). Matt told me this is the way to go. Atomization is not really an issue at this range of pressure; it still just sorta squirts out, and gets atomized mostly by the airflow. Greater pressure for a stock, NA application is basically just wasted gas (for burning purposes), tho it does help cool the combustion chamber if not ignited. The cat takes care of the unburned gas, tho excessive gas will clog the cat up.
4. Finally, install the header and run another test.
* Matt says I can safely advance the ignition timing a bit, so I will do that. (Stock is 10 BTDC for EFI Festys and Aspires). I think I have it at 10 now.
EDIT: Forgot to add that Matt said that our simple little gen1 economy-car EFI computers are not able to compensate for injector flow, by opening the injector longer or shorter. So for example a B6 injector would always run too rich. You would need an aftermarket system like Megasquirt to play with innjector parameters.Last edited by TominMO; 08-22-2013, 07:00 PM.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
hmmm, FSM suggests otherwise in the adjustment arena. i understood that that's the reason for the VAF in the loop, otherwise i would have expected to see a speed density system (MAP only).
so after reading the last few posts, is Matt hinting that i should lower the rail pressure back to or below stock to gain MORE mpg? as stated before, i've seen a steady 2mpg GAIN since adding the FPR at 42psi. if lowering the pressure will gain me more without loosing power, i'm all about it.Trees aren't kind to me...
Originally posted by FestYboy View Posthmmm, FSM suggests otherwise in the adjustment arena. i understood that that's the reason for the VAF in the loop, otherwise i would have expected to see a speed density system (MAP only).
BTW, since adding my front air dam, my average MPG for a tank of gas, while driving a combination of city/hwy, has risen from the 35-36 range to 39-40.Last edited by TominMO; 08-22-2013, 08:15 PM.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Festiva (Skippy, the one with the B3 head work).Trees aren't kind to me...
Originally posted by FestYboy View PostFestiva (Skippy, the one with the B3 head work).Last edited by TominMO; 08-22-2013, 08:17 PM.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
i wonder then why there is a variable signal from the VAF sent to the ECU, and why the car runs like poop when there is a hole in the intake tube after the VAF (mind you, the VAF door still stays open enough to trigger the fuel pump)?Trees aren't kind to me...
Using a static fuel pressure at the same settings and your mileage goes up may mean the stock FPR sucks and isn't holding steady, the new FPR is getting a better solid vaccum signal if you tee'd from another part of your plumbing. The more a computer has to hunt and play with its curves to hit its targets the more it adjusts fuel and timing, even though it has the best of intentions for emissions. This is also a dinosaur computer older than 50% of our members. Burning 14.:1 or stabbing at stoich is not the best for mpg, it's just the best for a cat converter. This is why some things are not for sale on california highway use vehicles, even tho it increases power and mileage...If you sit at a traffic light and press the brake all the way to the floor your vacuum changes because unmetered air is doing havoc. Some cars may even stumble. The computer has to play with its idle and timing to get it back. That itself is an emission spike. Air getting in the computer doesn't know about is a lean condition and if the o2 is working properly it will try its hardest to adjust what it can to come back. With a speed density and map sensor you can easily fool the amount of air measured. the VAF CAN be tuned as well, there are threads on it, mostly the turbo guys mess with it because they use a larger injector from another engine, hit their boost target on the fat side, and tweak VAF down to nail a fuel ratio.
I need to go to home depot and get an air dam myself, I think ill get great gains cleaning up my airflow. My aspire sure got quieter when i had the back end buttoned up.1993 GL 5 speed
The cam that I have have developmed for Tominmo is specifically designed to create a highly detination tolerant combustion enviroment. This will allow a much leaner idle & cruise circiut with more ignition advance for more complete combustion which would otherwise ping in a normal application. Reducing the FP is the only way to control fuel adjustment on this application. The stock ECU is a simple EFI stradagy system that only knows to target a narrow AFR range & has no ability to compinsate for changes. The stadagy is programmed to follow a preprogrammed load table using the VAF to assume load. Using this info, the ECU knows with a given injector size (for the B3) of 10.4 PPH how to calculate injector on time (pulse width)to maintain a desired AFR. If a larger injector were installed, the ECU has no way of knowing & will calculate the same injector on time but flowing thru a larger injector will create an extreme rich condition. As far as fuel pressure is concerned, it is commonly thought that the injector sprays a nice fuel mist. Most injectors spray a single stream which is rapidly broke up in turbulant intake flow. The primary reason for elivated FP is in boosted applications when delta pressure has to be taken into consideration. What this is is if you have 40 PSI of rail pressure & 10 PSI of boost your effective delta pressure is only 30 PSI. Which if not calculated will cause a devistating lean condition. As far as Festiva's & Aspire's are concerned, their EFI system works much like an on/off switch at WOT the ECU targets approximately 12.2-1 AFR. Since the injector on time cannot be reduced, the next option is to reduce FP. I have found 12.8-13.0 to have the best results. But this is all relative to the mods done to the engine. If engine performance is desired, air flow has to be increased as well as fuel volume. In this instance, bigger cams & ported heads with stock FP will create a lean condition, especially when throttle is rapidly opened as the EFI system has no "accelorator pump funtion" to compinsate enrichment when airflow is instantly increased, except the spike in FP when vacuum drops at WOT. To address this, FP has to be increased for best results. But there is a place where too much FP can cause excessive fuel heat retention & reduce the overall volume of fuel that flows thru the injector. Correct tuning for the application will vary but is paramount to achive best results.Last edited by mattdickmeyer; 08-23-2013, 09:34 AM.PROPOGATE! AND FACILITATE!
Matt just let me know that I should get my cam tmw, Saturday. I will install it Monday or Tuesday, and hopefully go on an MPG run on Wednesday. For this run I will advance timing to 13 degrees, if the plugs tell me I can (after a short test drive).
After that I will install his adjustable FPR and drop the pressure about four pounds, or roughly ten percent, and do another run. Again, I will check spark plugs prior to this MPG run, to make sure I am not going too lean.
Next will come the header test. Short run, check plugs, you know the drill....Last edited by TominMO; 08-30-2013, 05:27 PM.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Originally posted by TominMO View PostMatt just let me know that I should get my cam tmw, Saturday. I will install it Monday or Tuesday, and hopefully go on an MPG run on Wednesday. For this run I will advance timing to 13 degrees, if the plugs tell me I can (after a short test drive).
