Wow, slacker is kinda misleading...I enjoyed reading all that. If you still have
problems when you get this far northwest I can tune it in.
You should be at burning man.
With what you are doing the mileage is not as bad as it seems, but the new
set up should still be tuned in for best efficiency.
Is something holding the throttle open a little or is the little arm on the throttle
shaft on a stop that is adjustable?
