I already have missed a day of work cause of this tomorrow ill move the radiator out of the way an cut an access hole but I needed to see if this is the prob an not the axles
heeelllp installed clutch an hope all over
Frankie
fully custom 88 festy (project doomsday) Febuary in 2012 calander
Blockspire: ken block replica aspire
AdvancedDynamix: "If you put the same kind of effort into your engine that you put into the rest of the car, well... it'll be epic". thanks man
http://www.facebook.com/#!/profile.p...00000110128487
I'm still afraid to drive is I work 20 min from work all highway so it needs to be perfectFrankie
Mythbusters FTW!Originally posted by iceracerdude View Post"Perfection" I'm not so sure is going to be achieved...but I once heard a man say "failure is always an option!"
I didn't cut from up top, but rather I cut from the front facing side of the support. Easier that way.
Test drive for another win!Contact me for information about Festiva Madness!
During this processFrankie
That sweet festy was supposed to go to madness but wasn't done an time and as for the stuff removed I couldn't get the axle out so I tried moving everything out of the way it still didn't seem to workFrankie
Ok quick update: cut out the broken bolt an nut an installed new nuts an bolt so everything is tight.
Started the car an drove down the street much better but still bouncy. Chrisofna said I could have pulled the cv axle apart an one of the ends might have falled out in the boot.... anything else I should check.
Side note... it has new knuckles,starter,clutch, release bearing an I have a clutch cable on the wayFrankie
Didn't put the clutch disk in backwards did you?2008 Kia Rio- new beater
1993 Festiva- Fiona, DD
1997 Aspire- Babyspire, DD
1994 Aspire - Project Kiazord
1994 Aspire- Crustyspire, RIP
So icy have you ever expierenced this befor in yours I have the 97 four door I'm almost 90 0percent sure I broke an axle somehowOriginally posted by iceracerdude View PostSpoken like a guy with a screen name like...well, you see the irony here right?Frankie
So cut the boot band and see what happened...the inner cv will pull out, the outter cv is tricky to get apart...or break, unless it wears out over time.2008 Kia Rio- new beater
It really can be the only thing I can think of the engine has no problem befor the clutch an the trans mission is good too. I can get it up to about 35 befor it starts bad an at idle it doesn't bounce. It also goes into gear real well so I'm pretty sure I did it right. The only real problem I had was getting the axles out I yanked at it an think I broke somethin in the bootFrankie
