heeelllp installed clutch an hope all over
    I already have missed a day of work cause of this tomorrow ill move the radiator out of the way an cut an access hole but I needed to see if this is the prob an not the axles
    Frankie
    http://www.facebook.com/#!/profile.p...00000110128487
      I'm still afraid to drive is I work 20 min from work all highway so it needs to be perfect
      Frankie
        "Perfection" I'm not so sure is going to be achieved...but I once heard a man say "failure is always an option!"
          Mythbusters FTW!
          I didn't cut from up top, but rather I cut from the front facing side of the support. Easier that way.
          Test drive for another win!
            During this process
            Frankie
              frank Whats wrong with that sweet festy of yours
              ReD 91 L FIRSTiva
              92 silver 5spd with some boost! Kratos
                Why do you have so much stuff removed???
                1989 Carby L: Stock. Slow.
                1998 Mustang Cobra: ported heads, cams, longtubes, 4.30 gears
                2016 Focus ST: daily driven go-kart
                  That sweet festy was supposed to go to madness but wasn't done an time and as for the stuff removed I couldn't get the axle out so I tried moving everything out of the way it still didn't seem to work
                  Frankie
                  • #24
                    Ok quick update: cut out the broken bolt an nut an installed new nuts an bolt so everything is tight.
                    Started the car an drove down the street much better but still bouncy. Chrisofna said I could have pulled the cv axle apart an one of the ends might have falled out in the boot.... anything else I should check.
                    Side note... it has new knuckles,starter,clutch, release bearing an I have a clutch cable on the way
                    Frankie
                    • #25
                      Didn't put the clutch disk in backwards did you?
                      2008 Kia Rio- new beater
                      1993 Festiva- Fiona, DD
                      1997 Aspire- Babyspire, DD
                      1994 Aspire - Project Kiazord
                      1994 Aspire- Crustyspire, RIP
                      • #26
                        I don't think you can put one in backwards...
                        Famous Last Words: "How hard can it be?"
                        • #27
                          Spoken like a guy with a screen name like...well, you see the irony here right?
                          • #28
                            So icy have you ever expierenced this befor in yours I have the 97 four door I'm almost 90 0percent sure I broke an axle somehow
                            Frankie
                            • #29
                              So cut the boot band and see what happened...the inner cv will pull out, the outter cv is tricky to get apart...or break, unless it wears out over time.
                              • #30
                                It really can be the only thing I can think of the engine has no problem befor the clutch an the trans mission is good too. I can get it up to about 35 befor it starts bad an at idle it doesn't bounce. It also goes into gear real well so I'm pretty sure I did it right. The only real problem I had was getting the axles out I yanked at it an think I broke somethin in the boot
                                Frankie
