Originally posted by FestYboy
Sputters ..
Tonight i just checked it for spark and i got no spark, its getting fuel but no spark again. I hope this is not the ICM again how can that be or what else can it be crank position sensor?ignition coil ?Originally posted by Dom View PostEven with a full tank it was studdering until I slowed down and it just stalled out and will not start at all I get crank but that's it. I pulled the line of the fuel filter going to the rail and tried starting and a lot of gas shot out.
Festyboy - i checked that hose and it is fine..Last edited by Dom; 04-05-2013, 08:54 PM.
ok... you didn't mention the studder at full tank earlier in the thread (posts 39 and 44), so that's why i went to the tank pump hose...
ok, swap out the ICM (the one near the coil) (since you have a new dizzy), lets avoid that for the moment....Trees aren't kind to me...
I have to buy a new ICM?Originally posted by FestYboy View Postok... you didn't mention the studder at full tank earlier in the thread (posts 39 and 44), so that's why i went to the tank pump hose...
ok, swap out the ICM (the one near the coil) (since you have a new dizzy), lets avoid that for the moment....Last edited by Dom; 04-05-2013, 09:41 PM.
didn't you hit up a JY for one a while ago?
or is it that the 89 doesn't have the little 3 wire ICM near the coil? (internal to the dizzy...) i'll have to look at my FSM to verify...Trees aren't kind to me...
No 89 efi doesnt have it there, i bought a complete distributer with ICM and pick up coil complete.Originally posted by FestYboy View Postdidn't you hit up a JY for one a while ago?
ok, so it's like the carby dizzys.... well that makes it easier to diag what part has failed...Trees aren't kind to me...
diagnos first, THEN replace.... test light and DVOM are your best friends.Trees aren't kind to me...
Well it was the ICM just installed it and started right up, but it still is sputter really bad its doing the same thing before the ICM died on me. Also while the engine was running my hand tapped the spark plug cable and i got a zap from it,(what up with that ) short somewhere . really need some help guys this is my commuter car ...Originally posted by FestYboy View Postdiagnos first, THEN replace.... test light and DVOM are your best friends.
Thanks
Looking at your list I see you replaced your wires. Some of the manufactures wires dont fit as well as others (I like Bosch the best).Make sure each wire is seated properly @ Dizzy Cap & spark plug. The one that zapped you is not seated correctly thats all.Originally posted by Dom View PostWell it was the ICM just installed it and started right up, but it still is sputter really bad its doing the same thing before the ICM died on me. Also while the engine was running my hand tapped the spark plug cable and i got a zap from it,(what up with that ) short somewhere . really need some help guys this is my commuter car ...
ThanksSome people like to read fiction,I prefer to read repair manuals. Weird I know-
so i guess that would have nothing to due with the sputter ? this is my second ICM already.Originally posted by nitrofarm View PostLooking at your list I see you replaced your wires. Some of the manufactures wires dont fit as well as others (I like Bosch the best).Make sure each wire is seated properly @ Dizzy Cap & spark plug. The one that zapped you is not seated correctly thats all.Last edited by Dom; 04-10-2013, 06:16 PM.
Quite the contrary my friend,most likely it has a LOT to do with it.Originally posted by Dom View Postso i guess that would have nothing to due with the sputter ? this is my second ICM already.Some people like to read fiction,I prefer to read repair manuals. Weird I know-
The spark plug wires are new, they arent the greatest brand but they are new , i have a accel igntion coil running in it what spark plug wires would you recommened.? I will buy another pair and try that out.Originally posted by nitrofarm View PostQuite the contrary my friend,most likely it has a LOT to do with it.Last edited by Dom; 04-10-2013, 06:35 PM.
quick check: listen to the injectors and make sure they are all clicking.... may want to pull your plugs and inspect for one that looks out of place....Trees aren't kind to me...
