Nice tidbit for those with barely any heat
This is a sticky topic.
Originally posted by batstiva View PostJim has spoken, any other questions?
Originally posted by my03devilz View PostThanks! That does help.... he thought that was right... and do you know if the radiator capacity is 2 gallons? I can't find that on the forum anywhere...
1989 L - 247K miles Slick
Originally posted by batstiva View PostPer the owner's manual for my 90L, the coolant system capacity (Rad + Reservior) is 5.3 Quarts, or 5.0 Liters. Hope this helps. Unable (so far) to find specific capacity for just the radiator.He goes in this spurts, but so far I keep winning
www.mediafire.com/?b6ev0ssxaebjl8y
Click on the link and you will have the shop manual for a 1991 Festiva! I think it is somewhere on FF.com, but I found it on google (where else, lol):p
Ps. The "link" above will simply ask you if you want to open/save the pdf (mine shows up on the bottom of the screen).
Pss. Page 89 has the Coolant CapacityLast edited by Darlo; 11-12-2011, 11:28 PM.
nice first post. I just had to look up 41492 to see!! lol
welcome!! and thank you
likely. I would check rockauto and see what they've got on there or check the other sites for the aspire part numbers, etc
Originally posted by my03devilz View PostI had my 91 to the ford dealer a few years ago... they replaced the thermostat, still no heat. Defroster works, takes a bit but it eventually gets there. I was then told by the Ford dealer that there is no warm heat that comes from the vent, it was made that way, that's just a fan only with cool air. I called Ford themselves, and they confirmed it, that it doesn't have heat???? Anyone else hear this? I am having my husband take the thermostat out and going to try a Mazda one cuz I'm getting older, and getting colder, lol.... I can't go another winter without a warm car. I also recall a thread once where you can put insolation in, so after work, going to dig that one up!!
ford was correct, My car came withthe owners manual and it states also that you can not control the temp of the air from the dash vents only the floor and defrost. That messed me up before i read it because Mine was at normal temps and blowing cold air out of the vents..I was fixing to be depressed..lol
I ordered mine on eBay since I had some spare eBay bucks laying around. It's new, matches the Mazda part # 8AK1-15-171 -9U (does not include gasket) for $26.90 shipped.
Here's the link to the item: http://cgi.ebay.com/ws/eBayISAPI.dll...ht_1763wt_1163
I carefully flushed the cooling system on one of my Festys and installed the fabled Mazda 2-stage thermostat this fall. It has been -20C a couple of times already and I have not noticed any distinct improvement in cabin heat over that of my other identical Festy which just has a cheapy 192 degree thermostat.
Originally posted by Bert View PostI carefully flushed the cooling system on one of my Festys and installed the fabled Mazda 2-stage thermostat this fall. It has been -20C a couple of times already and I have not noticed any distinct improvement in cabin heat over that of my other identical Festy which just has a cheapy 192 degree thermostat.
If you look at the packages (or the specs online) you will notice that they are quite similar, and any differences would not (normally) be noticeable.
