WWW.clutchnet.com is the only place I have seen performance clutches.  They only had unsprung hubs before but I just looked and it looks like they offer sprung hubs on all the clutches now.  Can't hurt to look.
My B3-T setup
Not to sure. I know a disk will fit in the stock pressure plate but I don't think it will do any good. If you want good clamping force get a stronger pressure plate and get a sprung disk that isn't a puck clutch. They chatter a lot from what I hear.93 Festiva L White B6T
99 Dodge Ram STL Green Cummins. AKA the Jolly Green Giant
89 Festiva Blue
91 Green “Mad Maxine” Festiva B6T
93 Festiva GL Black BP automatic
93 Festiva GL Green stock
do it, b3t's are fun and i plan on turning up the boost next year. i barely got to ohiostiva, the car was finished the morning i left and had problems come up since then. its now winter so the car is away for winter and i plan on driving it a lot next yearOriginally posted by DriverOne View Post8PSI? That's pretty conservative. I highly recommend port polishing your head. Your exhaust ports are 90 degrees like a picture frame! They'll do well to have the corners honed a little. You've inspired me to mount my IHI VJ-11 to a B3.
Any updates on this one? Ever get a clutch to see what it'll do?89 L, hopefully returning from the dead soon with a little more power... :twisted:
http://www.fordfestiva.com/forums/sh...77-my-89-build
IIRC the VJ11 compressor wheel is identical to the VJ20...the main difference is the VJ11's use of the P20 housing which is a larger A/R than the P15 housing used by the VJ20. Lose some spool but gain plenty of top end with the larger A/ROriginally posted by bhazard View PostThe vj11 would be fine on a bp. Its a step bigger than the vj20 that came on the bpt and was good for a 2000 rpm spool on a 2.2...
The VJ11 would be good on the BP. Make a custom dump/downpipe for it though, the stock VJ11 dump is kinda crappy1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
Rocketchips!
Bolt-on Weber Carb Adapters!
^ well guys after alittle investigation an the info fom the last two posts I have realized that it is not a vj11 as was sold to me. It is in fact a vf13 off of a jdm "legacy twin turbo" and this is the amaller one and its def only good for a b3 b6 sohc setup sorry forthe bad info but that is what I was told that it was a vj11 and the last post about it being that.a vj11 is bigger than a stock bpt unit I looked at my turbo closer.because I knew it was way smaller than that it def turned up to be a vf14 I think (check me if im wron) and is way smaller than a vj11 and would do next to nothing on a bp but spool a 1g and drop off at 5gs
The VJ11 is not "bigger" than the BPT's VJ20 - they both flow the same CFM-wise but have different turbine housing A/R's
Post pictures & measurements of the turbo you have1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
Rocketchips!
