Well, an 8"-wide wheel is really closer to 8.5" overall (the 8" is a measurement inside the wheel lip) and with the 0mm offset you would have 4.25" of wheel towards the strut (which shouldn't be a problem) and 4.25" from the hub out. The wheels would stick out a good 2" past the fenders.
wheel/tire/suspension fitment thread
forgive me, i dont know much about tires and all that. what exactly is offset and how is that done? same with spacers. what WOULD fit with no issues on a regular setup? im not ready to do all of the mods but im kinda looking at getting a set of rims to spruce the car up when i get my paint job done hopefully in summer
Originally posted by perucho View PostWell, an 8"-wide wheel is really closer to 8.5" overall (the 8" is a measurement inside the wheel lip) and with the 0mm offset you would have 4.25" of wheel towards the strut (which shouldn't be a problem) and 4.25" from the hub out. The wheels would stick out a good 2" past the fenders.
Originally posted by MTec007 View Postforgive me, i dont know much about tires and all that. what exactly is offset and how is that done? same with spacers. what WOULD fit with no issues on a regular setup? im not ready to do all of the mods but im kinda looking at getting a set of rims to spruce the car up when i get my paint job done hopefully in summer
http://www.tirerack.com/tires/Spec.j...Potenza%20RE92
Offset is how much from the center the wheel mounting flange is. It's usually measured in millimeters.
Positive offset would mean that more of the rim sticks out away from the car. It's usually stated with a minus ( - ) sign. Like -25MM. In this example, just about 1 inch of the rim width will be toward the outside of the car (toward the fender).
Negative offset would mean that more of the rim is in toward the axle/strut area. Usually listed with a plus ( + ) sign.
The rim/tire combo above is very close to the stock size and is narrow enough to fit well with the typical sub compact wheel (approximately 13" x 5" with a +45 MM offset).
A spacer moves the wheel out away from the car (it goes between the wheel and the hub).Last edited by JPT; 03-15-2010, 07:01 PM.Festiva: Because even my dog can build a Honda.
Originally posted by MTec007 View Postso your saying the first size listed on that site is what im looking for?
There are other sizes that would work too.
If you want to keep the stock rims, another size that would work is 155/80-12. It's slightly taller, but fits fine (it's what's on my car now).
Originally posted by MTec007 View Posttrying to search that site for some 13's.. what car came with 13s (assuming they carry 13" rims)
Here's a few...
another size available is 175/60/13 slightly wider, and slightly shorter, but better traction.Trees aren't kind to me...
I am assuming 15/6.5 4x100/114 with a 40 offset will fit.
1993 Ford Festiva L ($650)
Mazda 1.8L BP - PaceSetter Header (in progress)
Aspire Swap - 15x6.5 wheels, 205/50/15 tires
>> Photo Album <<
thats what i have... it may be 6 wide but it may be 6.5 lol... i just cant remember...
Mike, AKA the sasquatch
sorry i forgot to post the link to what i was talking about
http://www.fordfestiva.com/forums/sh...ad.php?t=25048 8th pic down
i just picked up some 15x8" today. it is gonna be a really tight fit. they have 195/55r15s on them
i may be cutting the fenders out to make them fit.
