I'm now using 12" 120lb springs on the front of my setup as well. I think there is a write up that fell in between my original write up and Mike's write up that details the new setup. Sorry for the confusion. I've gotta take the time to clean all this info up into 1 basic article. I haven't done that because things are still being developed and new ideas are being implemented.
Ultimate Street suspension guide
This is a sticky topic.
Any further thoughts or progress on the ball joint lowering blocks?Trees aren't kind to me...
Originally posted by Grey Vw View PostI am very appreciative and thankful for this thread, but I am a bit upset. I assumed this was parts list was copy and paste from what Charlie does.
This front spring is 12" while in Charlie's thread it is 10". I now cannot achieve the ride height I wanted. With the collar all the way down and the shock length adjustment I cannot go lower than 3" fender to tire gap. Partially my fault for not doing thorough research. Please note this in your original post.
What sprig rates are you running?
I have 150 # 12 inch and with my springs preloaded to 10 inch my 165/55/14's only have an inch gap .
I am running a b6d with g series moved forward but
120 springs with stock engine and trans should let you go really low.Last edited by william; 02-10-2017, 11:57 PM.
The Capri knuckles do this without the blocks.Originally posted by FestYboy View PostAny further thoughts or progress on the ball joint lowering blocks?Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
I chose 150lb with the stock engine and tranny in preparation for the the eventual swap. I thought preload was just set by having the suspension fully unloaded and then just tightening it to keep the spring set compressed. If anyone better information I would appreciate itOriginally posted by william View PostWhat sprig rates are you running?
But you run aspire knuckles...Originally posted by Advancedynamix View PostThe Capri knuckles do this without the blocks.Trees aren't kind to me...
Have you tried running the shock tube all the way through the lower mount and putting the lock nut on the bottom?Originally posted by Grey Vw View PostI chose 150lb with the stock engine and tranny in preparation for the the eventual swap. I thought preload was just set by having the suspension fully unloaded and then just tightening it to keep the spring set compressed. If anyone better information I would appreciate itNo car too fast !
Thank you Dragonhealer! That's all it took to get the ride height I wanted. Saved me $100.Originally posted by Dragonhealer View PostHave you tried running the shock tube all the way through the lower mount and putting the lock nut on the bottom?
So I feel really dumb but im putting this together and I'm trying to figure out how to install the bump stops. It doesnt seem like they easily fit into the spring or easily go over the little nut at the top of the shock absorber easily. Do I just force the bump stop that came with the shock over that little nut thing and then the vw bump stop? also does the vw bump stop go bigger side up or down? sorry for the obvious questions lol.Last edited by fudge; 03-03-2017, 07:34 PM.92 Festiva L - bp & hydro g, advanced coilovers, aspire brake swapped
I cut off the largest bulb on the end of the bump stops. Helped it fit in the spring. I forced mine on the shaft but I imagine you could drill out the center of the bump stop a bit if you wanted to.Originally posted by fudge View PostSo I feel really dumb but im putting this together and I'm trying to figure out how to install the bump stops. It doesnt seem like they easily fit into the spring or easily go over the little nut at the top of the shock absorber easily. Do I just force the bump stop that came with the shock over that little nut thing and then the vw bump stop? also does the vw bump stop go bigger side up or down? sorry for the obvious questions lol.1990 L Plus Stock B3 automatic -scrapped- My First Festiva - RIP
1991 GL - B6d, g-series trans, aspire brakes, Advanced Suspension coilovers, Miata 7 spoke rims, '98 Prelude seats, more to come!
2005 Focus ZX4 SES - purchased from original owner, my grandmother. Currently my wife's daily. 210k
You can follow me on instagram @twfodor
I ground mine down with a bench grinder. I inserted a drill bit and applied just enough pressure to allow it to spin a little for a perfectly circular grind. It fits in the recess of the threads as well as within the spring. I will take a pic, since it's hard to explain.Last edited by bravekozak; 03-03-2017, 11:44 PM.
Originally posted by fudge View PostSo I feel really dumb but im putting this together and I'm trying to figure out how to install the bump stops. It doesnt seem like they easily fit into the spring or easily go over the little nut at the top of the shock absorber easily. Do I just force the bump stop that came with the shock over that little nut thing and then the vw bump stop? also does the vw bump stop go bigger side up or down? sorry for the obvious questions lol.That's what I did too. I cut the largest lobe off of the vw bumpstop with a hacksaw. Then I pressed real hard and it will slip past that little nub. Then I added the new kyb black one on top of that. The top of the black bumpstop stopped flush at the top the nub, so it didn't have to slip past it like the white vw one did.Originally posted by TWFodor View PostI cut off the largest bulb on the end of the bump stops. Helped it fit in the spring. I forced mine on the shaft but I imagine you could drill out the center of the bump stop a bit if you wanted to.
It's also mentioned on page 14 post#132 of this thread.
I put the black down first then the whit on top .
I don't think it really matters.
I also cut off the biggest bump but you can grind it down like stated above this will put you on the bump stops earlier and if you want a low ride height you maybe on the stops all the time.
Here's a shot of mine.
Sent from my SAMSUNG-SM-G900A using Tapatalk
There is no right or wrong way to put the bump stops on. It's okay to force them down over the register bushing on the shaft (the black KYB ones will go over that welded on bushing, if you push hard enough (I've done it about 40 times now)
If your shocks are making squeaky or grinding noises then you may have the top nuts too tight. The top rubber bushings only need to be squished a little bit (how much really depends on how old and hard your bushings are). If those top nuts are too tight, the shock can't articulate enough, and it will bend and flex the shock shaft. Those shocks go back and forth a lot when the car is being driven. That top mount NEEDS to flex easily.Last edited by Advancedynamix; 03-04-2017, 12:09 PM.Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
