Great job! You're going to love the way it rides!
Ultimate Street suspension guide
This is a sticky topic.
My suspension is on! Need to flare some fender-wells.Attached FilesWhoa, that was fun!
NICE!Any difference that makes no difference is no difference.
Originally posted by ottoparts View PostMy suspension is on! Need to flare some fender-wells.Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
Originally posted by ottoparts View PostMy suspension is on! Need to flare some fender-wells."The White Turd" 1993 Festiva 144k miles. (Winner of FOTM November 2016)
So right now festiver is running aspire springs with the aspire suspension I cut the front springs and put in spring spacers to stiffin the ride so I don't rub I want to go lower because I have 1.5" of wheel gap (proper) and 8" of ground clearance (monster truck) I definitely need to cut the fenders higher but the rear I only have 2-3" before I get the inner wheel well is the suspension you named above stiff enough I can run <1" of wheel gap without destroying everything over bumps and or rubbing the tires
Sent from my XT1585 using TapatalkFestiver
93 L find/5 speed
BP/g15mr swapped
Aspire brake swapped
stripped and sold due to rust
89 festie
rustful
93 festie
advanced suspension
kai/skeeter camber
b3t/g15mr
The 120lb/105lb rate is only slightly stiffer than stock, but the geometry of this setup and the dampening rate is such that the car will handle like a finely tuned sports car. This suspension is not your typical "tuner ride" that is harsh and bouncy. It's an improvement everywhere from stock.
The amount your tires contact your fenders depends on what tires you want to run, the offset and width of your wheels and your camber settings. With negative camber, and the right tires, you won't rub at all with slight wheel gap. Here are some examples of cars that don't rub at all or only a little in extreme cases. These cars all have rolled fenders, but the fenders have not been cut at all.
This is a 13x6 wheel, 12mm offset. Approximately 3.5" suspension drop. 175/50-13 tires. -3 degrees camber all the way around. No rubbing at all.
These wheels are 14x7 with a 15mm offset. The tires are 165/55-14. The suspension is dropped about 3.75". About 3 degrees negative camber all the way around. No rubbing and a really comfortable ride. Note: this car was driven like this for a 6000 mile road trip with no abnormal tire wear issues. It was very comfortable and was stable at well over 100mph. The car was raced in time trials racing at a local track and was capable of spec miata lap times on these tires. A very versatile setup.
The wheels are 15x7 with a 28mm offset. Tires are 165/45-15. Car is about 3.5" lower than stock. Camber is set at -2.8 degrees all the way around. Note: Car was driven on 6000 mile road trip with no abnormal tire wear issues.
The wheels are 15x6 with 43mm offset and 10mm wheel spacers for a 33mm final offset. Tires are 165/45-15. Car has a 3" drop from stock. Rear camber is stock, front is at 2 degrees. Note: all 3 cars in this photo have this suspension setup and are all daily driven by people over 50 years old. The two cars in the background have both been from coast to coast and back with no problems.Last edited by Advancedynamix; 07-10-2016, 09:34 AM.Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
Originally posted by Advancedynamix View PostThe 120lb/105lb rate is only slightly stiffer than stock, but the geometry of this setup and the dampening rate is such that the car will handle like a finely tuned sports car. This suspension is not your typical "tuner ride" that is harsh and bouncy. It's an improvement everywhere from stock.
93 L find/5 speed
BP/g15mr swapped
89 festie
rustful
93 festie
advanced suspension
kai/skeeter camber
b3t/g15mr
Originally posted by bhazard View PostCharlie do you still recommend 120/105 spring rates for full weight cars like mine? Are these all 10 inch springs too or?
150/120 for heavy loads.Last edited by Advancedynamix; 07-11-2016, 12:13 AM.Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
Okay. Currently have 200 fronts and 140 rears but when I put my mk1 rear setup together I'll prolly go for 120s and maybe put the 140s up front. This is the automatic car by the way.
What about the spring length?91GL BP/F3A with boost
You'll want 10" Brad. You can get away with 12" (fronts, 12" rears aren't available in the 1.875" springs) if you don't want to lower the car much. 8" (front only) will work but could be bouncy with a 140lb spring (the shorter the spring the steeper the rate rises.)Last edited by Advancedynamix; 08-02-2016, 01:32 PM.Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
