My KLZE Festiva Build Thread
  • Originally posted by Damkid View Post
    Thanks, hopefully once the new motor is in, it'll be better and more powerful then before :evil4:
    This is the natural progression of things. I swear every bp i've replaced has been stronger than the last.
    cya at FM6.
    -Greg
    Redneck Engineer
    FOTY - '09
    • Originally posted by Flyin4stroke View Post
      Don't worry you aren't the only one with an engine swap to do before madness. Cutting it close this yr.
      I have one also to do with a wire tuck.
      Ford Fester
      • I'm workin on my motor swap as well before madness haha
        -Josh R
        • I think your catch can might not have worked because there's no breather on it. Afaik, that's necessary, otherwise the turbo is putting vacuum in the motor, sucking the oil out and baffles won't stop it. The PCV system works under mild pressure, it wasn't designed to work properly with high crankcase pressure or under vacuum.
          Your catch can with an extra tube and a filter on the turbo side of the baffle should work properly.
          • ^^then explain why when I disconnected the can from the turbo.... Meaning no extra vacuum in the can.... The can sprayed oil all over my engine bay, literally like a friggin garden hose
            • When things are located properly and the engine is in good order (i.e. no excessive blowby) the catch can will work great under a vacuum. Engines make more power with their crank case under vacuum.
                There are a bunch of us cutting it close. Had to swap into a GTX bottom end.
                And a taller 5th gear
                • Current state.... Hoping to fire it up tonight
                    That would be excessive blowby. I didn't catch that part.
                    Yes, yes it does, but those systems also utilize catch systems with vents (the ones I've seen) or vent directly to atmosphere via the vacuum pump outlet instead of venting oil mist back into the intake stream. The latter leaves oil buildup under the hood unless a vent tube is installed to direct it.
                    The only system I know of in OEM configuration that doesn't rely on crankcase pressure is on older Honda (granted, I don't have a lot of specific information about PCV systems). They use a venturi duct in the intake stream that induces vacuum under load, actually pulling the gasses through the tube instead of them being deposited there as is typical.
                    Most aftermarket CAI's or SR's don't have the same type of venturi duct in them, so the PCV system doesn't operate as it was intended when those things are added to that type of engine.
                    I have a half-backside redneck mod idea to use a AIR pump (which is not positive displacement) to vacuum the block. I'm not sure if they'll pull enough CFM to be effective, though. I've heard that you don't want to exceed a few inches of vacuum so you don't pull the seals in, but I don't really see that actually happening, considering the shape of seals.
                    • I have 3 to build, I don't wanna hear it
                      -Greg
                      Redneck Engineer
                      FOTY - '09
                      • Oh I know my car will be driving by FM6, I just don't know if my bank account will be ready for FM6
                        • ^x2. Hopefully I can bribe people to give me money for my b-day so it will pay for gas.
                          1989 Ford Mustang GT 5.slow
                          1996 Ford F-150
                          • Originally posted by eurotiva View Post
                            I thought only 2 left ?
                            93 L B6T DD http://www.fordfestiva.com/forums/sh...ad.php?t=37751
                            RIP_90 LuX http://www.fordfestiva.com/forums/sh...ad.php?t=32249
                            RIP 88 LX / B8-MEhttp://www.fordfestiva.com/forums/sh...ad.php?t=26398
                            RJ
                            • KL #2 is in the engine bay now just gotta finish hooking it all back up and it should fire up first shot
                                Jeebus you work fast, dude.
