My KLZE Festiva Build Thread
  • I tried taking off the IAC and it still doesn't clear, I'll be rebuilding the whole intake once i get the intercooler
    I finished cleaning up the fuel rails and got installed the 929 injectors (330cc) for the first while since i probably will only run low-ish boost at first (10-15 psi) then later i'll upgrade the turbo etc. since it's just not in the budget right now
    comparison pic of before and after
    both rails cleaned up
    and injectors installed, they fit like factory so thanks hppwdn for the tip on the 929 retainers
    now i just gotta make an injector harness and that part of it is done at last
    • I bought a turbo that was on an SHO......you need it
      -Greg
      Redneck Engineer
      FOTY - '09
      • Originally posted by Damkid View Post
        hahaha you crazy guy...so if that's "low-ish" boost, what's full? 30psi?? I will come see this thing in person just to ogle it.
        • Originally posted by eurotiva View Post
          Hmm I maybe interested but I gotta get some other things paid off first before I get to buy more car parts :lol: stupid priorities
          I probably will run 25ish psi one day
          • I guess Ive missed this thread , props for the build - keep us updated. When done right , Custom intakes make alot more powa.
            :thumbright:
            • ^^Thanks
              Yesterday my festiva overheated cause it lost all the anti-freeze, so today i looked and saw this
              Now i get to change another water pump...... yay
                ^^Thanks
                Water pump block-off plate and electric water pump?
                Current cars:
                • ^^Very tempting, but since the last time i changed the pump i threw a used one on it, i'll put another stock replacement on it and see what happens, if a new pump goes within the first year, i'll get an electric one for sure
                  • Yeah don't you have to pull the engine every time you change a water pump in that thing? If that's the case when I do one (SHUTUP IT WILL HAPPEN) I'm instantly doing electric water pump, lol.
                    Current cars:
                    • i pulled the engine to change it the last time so i didn't fight with clearance (not knowing how much clearance i would have either) but i also wanted to change the clutch while i was at it (other reason for pulling the engine)
                      When i changed the timing belt, i did it with the engine in the car so i'm sure i can change the pump in the car as well (thank god lol)
                      • I really hope you won't have to pull the engine for that! when I read that you'd be replacing it on page 19 that's what I was thinking!!
                        can you lift up the passenger side to give a touch of room or does it even have any room at all?! lol
                        Walth
                        Festiva #1: 91 Red L 4/5
                        http://www.fordfestiva.com/forums/sh...ad.php?t=27981
                          but yes if i need room i can lower the tranny down and jack up the engine side to make room
                          • wow...well, that certainly beats pulling the engine anyday! especially in your case
                            Walth
                            • I can go from a running car to the engine out in about 1hr 45mins, it really is not bad to work on because of how much "extra" crap I kept out of my engine bay
                              • Friday it took 2 1/2 hours to change the water pump from start to finish
                                Here's how far down i had to tear it apart
