Project Tin_Can - b8 SOHC install
  • #76
    Originally posted by FB71 View Post
    Trevor, block off the breather, brake booster, FPR and anything else connected to vacuum. See if it makes any difference.
    You thinking cracked manifold? A buddy and I were just talking about that
    92 GL - parts car
    97 aspire - parts car
    87 323 DX - daily driver
    • #77
      *** update ***
      So festyboy helped me get the thing running
      The good news is it now runs after going through the electricals
      The bad news is it has a rod knocking now so it still sits
      92 GL - parts car
      • #78
        ^ seriously...
        What was the problem? And now what do you need from the jy new block or are you going to rebuild it?
        • #79
          Turbo it with a 100-shot just to see what it'll do at the drags; blow it up; then stick in another B8.
          • #80
            What was the problem that kept it from running?
            I don't suppose you had any sort of warranty with the engine?
            • #81
              We did a lot of checking fuel and ignition and pump and intake finally we let it dry out adjusted timming and tried with all the b3 stuff then one by one started adding the b8 stuff
              I may rebuild I may replace
              92 GL - parts car
              • #82
                Hey Trevor, did you see this?
                http://www.kyboutlet.com/vaf/product...=80&model=1551
                • #83
                  problems found: timing off two teeth, dizzy rotor off 120*, plugs came out compleatly wet, bottom end knock once fired. needs rebuild.
                  • #84
                    that suxs, dont give now you have an excise to build a turbo motor!
                    • #85
                      Checked out a rebuild cost and its more than the cost of the motor so not sure yet
                      92 GL - parts car
                      • #86
                        Go to a yard and buy a b8 it'll be cheaper IMO. Even if it's a day drive.
                        -Greg
                        Redneck Engineer
                        FOTY - '09
                        • #87
                          I would have to find a day to go because there are no B8's near me
                          92 GL - parts car
                          • #88
                            might be able to relay a block to you....
                            • #89
                              Sounds good give me a call to work out the details
                              92 GL - parts car
