My 2002 Protege 5, KLZE to KJ swap
  • #61
    awesome build!!!!!drool
    • #62
      You may hate wiring but you have the experience and "talent" if you will to track down why some of the wiring is not cooperating. I've thrown in towels because of this sort of thing. You're getting there, it will be nice to see the end result.
      1993 GL 5 speed
      • #63
        Thanks, and yes i will get this swap finished despite the wiring issues, i'm in too deep to give up now lol, just gotta figure out which ECU pins are for the TPS and the other connectors and i'll be good to go
        • #64
          A colleague of mine was gloating about the great deal he just got on an uncertified but e-test-passed 02 Protege. We looked underneath and the subframe under the front floor (on both the drivers and passenger side) was completely rotted out. Car looks great from the outside but in reality is on the verge of breaking in half. Are they known for this?
          He wasn't even remotely gloating when he left, and I have no desire to try bolting a much newer 2.0 litre Mazda engine into anything I own either.
          • #65
            I'm not sure if its a common problem or not, but mine is in great condition underneath, the only spot that i believe is common for rusting is the rear whel wells (mine is starting to rust there, but it's not bad yet) and around the rear emblem
            • #66
              So i got my pin-out diagram and i've been digging through the harness a bit more, and i think i'll end up cutting the harness all apart and re-wiring everything myself
              It seems that the sensors/selenoids get power from multiple points in the harness and tracking them all down with be a real PITA with the possibility that i'll miss something here or there, so by re-building the harness to how i want it, i won't miss anything
              • #67
                If you need diagram I can get you some if you are missing something
                • #68
                  Thanks maxim but I already found all the diagrams I need
                  Ive spent this afternoon working on more wiring, it's coming along and I've got 90% of it figured out, a couple more hours and I should have the wiring finished up
                  Then a bit of exhaust work to do to clear the steering rack, make the engine mount, and hook everything up
                  • #69
                    More wiring work.... i'm probably about 90% done with wiring
                    Did I mention I hate wiring
                    And all these wires, i need to run to the computer, they are for the front 3 coils, TPS, IAC, cam positioning sensor, front 02's etc.
                    • #70
                      Wiring harness is now in the Protege, just need to connect power the 5-6 wires that need it, get the KJ back in the engine bay, and i'll be trying to fire it up, hopefully tomorrow night
                      • #71
                        Sweet!!!
                        Good luck
                        • #72
                          W00T W00T!!!!!!! FIRST START UP!!!!! :wav:
                          • #73
                            Rocketman likes this
                            1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
                            Rocketchips!
                            Bolt-on Weber Carb Adapters!
                            • #74
                              Damkid likes this too
                              • #75
                                Doing it.
                                14 C7 Z51
