A little added water displacement under the car for good measure. Lol.
Ian's B6T Festiva build
Last edited by Advancedynamix; 04-26-2016, 12:53 PM.Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
Boost gauge is in and hooked up, gauge pod installed, water/meth system all wired up. The controller for the injection setup is in the glove box.
Turned the engine over with no plugs in and oil pressure came up quickly. Gapped the new spark plugs and put them in the tried to start it up for the first time with no luck.
I had checked that cylinder #1 and the distributor were in the right positions. Checked that I had the fuel lines hooked up correctly... the line from the filter goes to the fuel rail with the line off the fuel pressure regulator going back to the tank.
The fuel pump is turning on, at least when I open the door in the VAF meter. That's as far as I got yesterday. Will be checking to see if there is actually fuel at the rail and then checking for spark.
I'll be back in the garage later today and will keep you posted!Last edited by fastivaca; 04-29-2016, 08:42 AM.Ian
I was actually texting you when this post popped up!Originally posted by shadetree View PostGrounds ... Check all the grounds . Listen for inj hum .Ian
Make sure the green 3 pin plug, that lives near the coil is, clean and plugged in securely. It's very important.Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
Ian
Still no start but I've narrowed it down to ignition as there is no spark at the plug. Going to be working back from there to narrow it down further.Ian
Even with the frustration with the car not starting I did mange to get a couple of things done...
Painted and installed the strut bar...
I was originally a much different blue than the car and didn't go well with the red valve cover.
Just about have the rebuilt console ready to go in. The one from the red car had a couple of cracks so I redid one for this car...
Thanks for your continued interest.Last edited by fastivaca; 04-30-2016, 08:53 PM.Ian
Cool, where did that console come from?Originally posted by fastivaca View PostEven with the frustration with the car not starting I did mange to get a couple of things done...
Thanks for your continued interest.Jack Byrd,
1991 Capri
1988 Festiva LX, 240K
1970 Chev C10
1977 Airstream Argosy MH
The console is stock Festiva with the cup holder assembly coming out of an early Protege. I cut down the internal box of the Festiva console so that the cup holder could fit in. There was a thread a long time ago done by forum member monkeyracing but don't know if that is still around.Last edited by fastivaca; 05-01-2016, 11:03 AM.Ian
How well does the strut tower brace work?1990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
19?? 150$ burnout car SOLD
1991 (STRESS RELIEF)SOLD
Can't really say it improves handling by any quantifiable amount but it does "feel" better than running without it.Originally posted by mikemounlio View PostHow well does the strut tower brace work?Ian
Finally some good news.... we have spark. Not sure what I did but apparently unplugging stuff then plugging it back in works wonders. Still not starting so we're thinking the injectors might be really dirty and not opening... they have been sitting for four or more years. Going to pull the injectors now, give them a good clean and then see what happens. Hopefully we'll be making noise very soon.
IanIan
