Great looking Festiva and its my favorite color! Making me jealous over here
Ian's B6T Festiva build
1990 L Plus Stock B3 automatic -scrapped- My First Festiva - RIP
1991 GL - B6d, g-series trans, aspire brakes, Advanced Suspension coilovers, Miata 7 spoke rims, '98 Prelude seats, more to come!
2005 Focus ZX4 SES - purchased from original owner, my grandmother. Currently my wife's daily. 210k
You can follow me on instagram @twfodor
Made some more progress today. It's still running a bit hot but at least the cooling fan is working!! Turned out to be a dirty connection in one of the plugs. Will continue to work on the heat issue and then I'll figure out the tach.Ian
Running the stock gauge with a 323 sensor. I was thinking of checking to see if the Festiva and 323 sensors were different. Other than the gauge you can tell it runs hotter than the B3 just opening the hood! Charlie suggested that I do my best to get all the air out of the system. I'll be doing that later today.Ian
You probably know, but jack the front drivers side of the car up real high while warming it up with the rad cap off untill it flows real well. Then install rad cap and run it for a while still jacked up till the fan comes on. Then lower and drive a bit. What thermostat do you have? I still have a real hot one in my car that i like for the winter because it keeps the gauge over half way up even in -30c. But when it is +30 like the other day it looks a bit high. Like this:
When its only +20 out or even down to -20 it is about here:
Even at minus 30 its just a hair below that, so nice.
If i take my IR temperature gun out the block and the oil seems to be at 200 degrees, which is only 5 over where the thermostat opens. Fans on my civic turn on at 205, not sure about the festiva. My fan is on a switch and this is with no fan on. I will be installing more accurate gauges with number readouts soon for oil and water. Also a different thermostat i think, lol
If you dont have one of those temp guns keep your eye out for one on sale. This is the first one that came up on google if you dont know what im talking about http://cf-t.com/product/milwaukee-22...FceCfgodsB4Kvw
I use mine all the time for all kinds of stuff. Canadian tire had it 80% off for $40 or so at the time.
Coolant at the proper mixture can safely get to 230f, but thats the hottest i would ever let anything i own get and where your sensor is is not nessacarily the hottest spot and any gauge isn't necassarily super accurate and you dont want it that hot of course and just driving around it should never get close to that. But i dont worry too much about anything below 210f if the coolant is new and properly mixed with a good pressure cap.
Sent from my iPhone using TapatalkLast edited by ryanprins13; 05-08-2016, 12:03 PM.
One of many more photos to come...
Ordered a new thermostat from Mazda today. I'll put that in and bleed the cooling system later this week.Ian
Beautiful! droolAny difference that makes no difference is no difference.
I agree with Shadetrees' advice.Originally posted by shadetree View PostChange the temp sensor to the Festiva sensor . Let it run with rad cap of for ten min or so !
In the longer run, with the B6T in the car you should think about putting an after market, accurate temperature send and gauge in the car. I like having a boost gauge and a wide band air/fuel ratio gauge to monitor things too, but the truth is those two gauges are useful only when you are tuning the car or monitoring it for some problem. After it runs well you would rarely look at them, but when it has a problem they are invaluable.
The car looks really lovely Ian, well done!Thricetiva replaced Icetiva as the new ride
Icetiva-3-race-car-build
Thanks Jed.Originally posted by Icedawg View PostI agree with Shadetrees' advice.
The temp gauge is on my "next up" list along with the oil pressure gauge. I have VDO gauges for both already but the senders I have are not the correct threads. I'll be looking into those very soon. If you're down this way at all perhaps we could hook up for a coffee or something.
Cheers
IanIan
Hope you don't mind. GRM on Facebook asked what your favorite hatchback is. I posted a pic from this thread. If you don't want it there I'll delete it.Last edited by sketchman; 05-10-2016, 10:14 AM.Any difference that makes no difference is no difference.
Not a problem. Thanks for sharing it!Originally posted by sketchman View PostHope you don't mind. GRM on Facebook asked what your favorite hatchback is. I posted a pic from this thread. If you don't want it there I'll delete it.
IanIan
I picked up a well used MIG welder a year or so ago to help with this project. I'd not done any welding prior to this!Originally posted by blowby View PostWhat kind of welder for this kind of work. Thanks
IanIan
Did you order the dual element thermostat from Mazda? They are listed for the 89-93 miata iirc. It's got 2 elements and helps the car warm up faster and then run at the proper range better.Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
