Ian's B6T Festiva build
  • Wow! You beat flat rate. I am anxiously awaiting the results to this experiment.
    • That must have been a red bull not a beer, Ian, that was seriously fast between the two posts for getting the T re-installed. You sure did beat flat rate, and better!
      Icetiva-3-race-car-build
      • Not too sure if you can see what I mean about the inside ends of the release levers, or fingers, or whatever they're called, being almost 1/2" closer to the disc!
        Here's a shot of the Spec pressure plate with the Spec disc with the release fingers pointing in towards the flywheel:
        Here's the Spec pressure plate with the Exedy disc with the release fingers pointing towards the transmission:
        The result was that with the thicker Spec disc the release bearing had to move an extra 1/2" to engage the fingers and then there wasn't enough room to remove pressure off the disc, the fingers would actually hit the disc!!! With the Exedy disc installed the fingers point towards the transmission and are much closer to the release bearing.
        I may just contact Spec to see what they have to say.
        Thanks again for the encouragement!!!
        Ian
        • Wow that spec looks like it won't have disengaged.
          • Originally posted by william View Post
            That's exactly what was happening. No matter where I had the cable adjusted the clutch did not disengage. 😠
            Ian
            • A major mileatone this evening!
              Took the car for a spin around the block!!!! The clutch is doing what it's supposed to do. Boost gauge works.
              Still to do:
              - get the tach working.
              - find an oil pressure sender I can just screw in without adaptors. I'm pretty sure I can get some from VDO.
              - driver's side front speaker isn't working, probably just came unplugged.
              - Main console to go back in along with the e-brake cover.
              - figure out why the daytime running lights aren't working.
              - aim the headlights
              - double check toe-in/out up front... it looks a little off.
              -figure out how much bump stop to put on the rear shocks
              - adjust the front coilovers as the cat is sitting a bit lower than when they were on the red car.
              - head to the car wash!
              Will get some daytime photos very soon.
              Ian
              • Nice! Must have felt good to finally be able to drive it! what was the spark problem you had earlier?
                • Originally posted by ryanprins13 View Post
                  I had missed one splice in the wiring harness and to make things even more interesting I hadn't installed the fuel injectors correctly.
                  Ian
                  • Great news !! Now the fun begins , try to find time to finish it between test drives !!
                    It's really major self accomplishment .
                    New build on the way .
                    • Originally posted by shadetree View Post
                      Thanks Rob. Your help was invaluable in getting things to this stage.
                      Ian
                      • It's been a long road with a few twists and turns and changes of direction but it's finally out of the garage and into the real world....
                        Now comes the fine tuning.
                        Ian
                        • Man that looking amazing! well done.
                          • Another shot from earlier today....
                            Ian
                            • The colour and the front bumper look great!
                              • Man, that looks absolutely fantastic. You gotta be a proud papa. Love the wheels.
                                Jack Byrd,
                                1991 Capri
                                1988 Festiva LX, 240K
                                1970 Chev C10
                                1977 Airstream Argosy MH
