Originally posted by Advancedynamix
Lucifer gets new Turbo setup!
How do i set it up correctly? All i know to do is hook it up and set it to like 8psi or something. I have the smallest nozzle that they sold.1990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
19?? 150$ burnout car SOLD
1991 (STRESS RELIEF)SOLD
idle valve is fixed. I still dont have the DV on the car. I need to find a reduce or something so i can adapt to my valve.1990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
Just bring me Lucifer I'll make him all better ^_^
By the way figured out what's wrong with my ecu...diode popped off its post. Need to solder it back together. Might need replaced. Might still be bad even after that. But it's obvious.91GL BP/F3A with boost
Do you have a controller or just a switch? If you have a controller you can have it spray at 5 or 6 psi, and ramp it up to max boost.Originally posted by mikemounlio View PostHow do i set it up correctly? All i know to do is hook it up and set it to like 8psi or something. I have the smallest nozzle that they sold.Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
no controller! Just a psi switch1990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
If i had vacation time left i would bring Lucifer down there and let you go at it! Ill have to work on it myself or find someone near me thats pretty good.1990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
I have a ms diy v2. Its pre built and ready to go. I just dont know or have the wiring to hook it up.Originally posted by Flyin4stroke View PostIf you have any boost leaks it will seem super laggy. You can change how the turbo spools with Ecu timing.1990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
Lucifer needs new tires again! This time around i think ill try the 185/55/14 595 federal tires. They say they are a 260AA tire. No clue how long they will last tho. Guess we will find out.
Near future plans for Lucifer:
1. Finish installing the water meth kit.
2. Figure out something to help the exhaust! go back to normal exhaust or make the fender exit work.
3. remove rear seat supports.
4. install Corbeau seats.
5. make flat cards for rear panels
6. install rear shims.
7. set ride height/preload
7. set camber and toe in front.
8. make harness bar.
the list goes on!1990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
I am looking for ideas on how to get my car to run better.
I am thinking that timing may be an issue for me right now. I am going to be checking for boost leaks and the such and trying to get my diverter valve hooked up this weekend. I hope that will aid my spool up times. Also i will place an order for a new psi switch so i can finish my water meth kit. That again will help my spool times every so slightly (i hope).1990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
A bigger engine will spool that big turbo a bit faster. KLZE?~Nate
Current cars:
FOTY 2008 winner!
Britstiva will get a bigger motor. Lucifer will at some point get a garret gt2554. this car is meant for autocross so it needs to stay light and quick to spool. I took a chance on this turbo to get my by for now! The plan was always to have a propper mani built for me and to run a good turbo. I wanted it back on the road asap so i went cheap.Originally posted by skeeters_keeper View PostA bigger engine will spool that big turbo a bit faster. KLZE?1990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
The diverter should make the most noticeable difference. Also, did you fix the idle valve routing?Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
