Lucifer gets new Turbo setup!
    Did you fix the idle valve routing and DV setup?
    Also, restricting the exhaust and adding pressure is a really bad plan. You'll increase cylinder temps and pressure without gaining much. It's a really good way to burn your piston tops away.
    Remember, boost doesn't make HP without flow.
    Also, water meth injection will help the turbo spool quicker if you set it up correctly.
    How do i set it up correctly? All i know to do is hook it up and set it to like 8psi or something. I have the smallest nozzle that they sold.
    19?? 150$ burnout car SOLD
    1991 (STRESS RELIEF)SOLD
    • idle valve is fixed. I still dont have the DV on the car. I need to find a reduce or something so i can adapt to my valve.
      • Just bring me Lucifer I'll make him all better ^_^
        By the way figured out what's wrong with my ecu...diode popped off its post. Need to solder it back together. Might need replaced. Might still be bad even after that. But it's obvious.
        91GL BP/F3A with boost
        • 91GL BP/F3A with boost
          • Originally posted by mikemounlio View Post
            Do you have a controller or just a switch? If you have a controller you can have it spray at 5 or 6 psi, and ramp it up to max boost.
            • no controller! Just a psi switch
              • If you have any boost leaks it will seem super laggy. You can change how the turbo spools with Ecu timing.
                1989 Ford Mustang GT 5.slow
                1996 Ford F-150
                • If i had vacation time left i would bring Lucifer down there and let you go at it! Ill have to work on it myself or find someone near me thats pretty good.
                  • Originally posted by Flyin4stroke View Post
                    I have a ms diy v2. Its pre built and ready to go. I just dont know or have the wiring to hook it up.
                    • Originally posted by bhazard View Post
                      It's broke.
                      1996 Ford F-150
                      • Lucifer needs new tires again! This time around i think ill try the 185/55/14 595 federal tires. They say they are a 260AA tire. No clue how long they will last tho. Guess we will find out.
                        Near future plans for Lucifer:
                        1. Finish installing the water meth kit.
                        2. Figure out something to help the exhaust! go back to normal exhaust or make the fender exit work.
                        3. remove rear seat supports.
                        4. install Corbeau seats.
                        5. make flat cards for rear panels
                        6. install rear shims.
                        7. set ride height/preload
                        7. set camber and toe in front.
                        8. make harness bar.
                        the list goes on!
                        • I am looking for ideas on how to get my car to run better.
                          I am thinking that timing may be an issue for me right now. I am going to be checking for boost leaks and the such and trying to get my diverter valve hooked up this weekend. I hope that will aid my spool up times. Also i will place an order for a new psi switch so i can finish my water meth kit. That again will help my spool times every so slightly (i hope).
                          • A bigger engine will spool that big turbo a bit faster. KLZE?
                            ~Nate
                            Current cars:
                            FOTY 2008 winner!
                            • Originally posted by skeeters_keeper View Post
                              Britstiva will get a bigger motor. Lucifer will at some point get a garret gt2554. this car is meant for autocross so it needs to stay light and quick to spool. I took a chance on this turbo to get my by for now! The plan was always to have a propper mani built for me and to run a good turbo. I wanted it back on the road asap so i went cheap.
                              • The diverter should make the most noticeable difference. Also, did you fix the idle valve routing?
