Festiver build thread
  • So I brought my 3k mile injectors to school along with a multimeter a 9v and some alligator wires just tapped the power a bunch of times and the injectors freed up and started ticking again so yay to that gonna do a carb cleaner soak to help get rid of junk
    Festiver
    93 L find/5 speed
    BP/g15mr swapped
    Aspire brake swapped
    stripped and sold due to rust
    89 festie
    rustful
    93 festie
    advanced suspension
    kai/skeeter camber
    b3t/g15mr
    • Oh and my ohms were
      15
      15.2
      15.1
      15
      Seems pretty ok to me but I'm not very knowledgeable about injectors and such learning still
      Festiver
      93 L find/5 speed
      BP/g15mr swapped
      89 festie
      rustful
      93 festie
      advanced suspension
      kai/skeeter camber
      b3t/g15mr
      • Ok so I'm having a problem now with the injector harness with the car in the run position I get power to both sides of each injector no ground signal but if I test the wires coming to the plug from the chassis everything is ok green with yellow has a ground and 0.1 I'm guessing resistance to the battery (I'm using a power probe) and green with a black is the same and the yellow with a black has 12v which makes sense so I check the injector sub harness and everything works perfect that's my problem everything works perfect till you put it together then the injectors don't get signal
        Festiver
        93 L find/5 speed
        BP/g15mr swapped
        89 festie
        rustful
        93 festie
        advanced suspension
        kai/skeeter camber
        b3t/g15mr
        • So it runs with the old inj but won't with the new inj ?
          have you cleaned them. ?
          New build on the way .
          • Hey text me I lost your number because my phone broke but no now it won't run on either injectors but the injectors work
            Festiver
            93 L find/5 speed
            BP/g15mr swapped
            89 festie
            rustful
            93 festie
            advanced suspension
            kai/skeeter camber
            b3t/g15mr
            • Originally posted by shadetree View Post
              Sorry that was confusing the injectors themselves are ok but the injector signal is all wacky
              Festiver
              93 L find/5 speed
              BP/g15mr swapped
              89 festie
              rustful
              93 festie
              advanced suspension
              kai/skeeter camber
              b3t/g15mr
              • I've triple checked all my grounds and wiring the only thing I can think to blame is the ecu
                Festiver
                93 L find/5 speed
                BP/g15mr swapped
                89 festie
                rustful
                93 festie
                advanced suspension
                kai/skeeter camber
                b3t/g15mr
                • Well not the ecu I threwy old b3 one back in and still no injectors firing
                  Festiver
                  93 L find/5 speed
                  BP/g15mr swapped
                  89 festie
                  rustful
                  93 festie
                  advanced suspension
                  kai/skeeter camber
                  b3t/g15mr
                  • Originally posted by Festiver View Post
                    Power probe + ECU = broken drivers...
                    KOEO should show battery voltage on both sides of the injector plug when backprobed because there is no voltage drop because there is no ground being provided. And seeing battery voltage on either side shows that the injector winding is intact.
                    Now given that, are you getting spark? No spark points to the dizzy pickup and that will also disable injector pulse signal.
                    Please be careful with use of power probe and any ECU related wiring... Prefer to use DVOM.
                      I was worried I'd hurt the ecu lucky I haven't so far somehow a bad short was in the injector harness connecting both green wires and the yellow black wire stripped and rewrapped the loom and now she squirts fuel again oh and my ignition is in great shape
                      Festiver
                      93 L find/5 speed
                      BP/g15mr swapped
                      89 festie
                      rustful
                      93 festie
                      advanced suspension
                      kai/skeeter camber
                      b3t/g15mr
                      • Good to hear
                        • OK so I go out today and put my fixed injector harness in and no start I bump into the disty plug on accident and I hear the inject give a little squirt. Hmmm OK so I play with the plug a little bit fired up almost instantly (yay) so I clean up all the connections and it's all good I swapped the thermostat to a 180° that I had in my old BP and I had to lean out the vaf a little plugged the IAC in and it runs sooooo good idles perfect revvs perfect doesn't stumble or miss I'm so happy now for every up there's a down lol my inter shaft bearing is chiping rip so I'm gonna have to replace that now but it's OK I'm so hyped also don't get upset about the revving it was all up to temp and was running for a while before lol https://vimeo.com/196984176
                          Sent from my XT1585 using Tapatalk
                          Festiver
                          93 L find/5 speed
                          BP/g15mr swapped
                          89 festie
                          rustful
                          93 festie
                          advanced suspension
                          kai/skeeter camber
                          b3t/g15mr
                            Yeah, I disconnect the ECM control and leave the coolant hoses hooked up. The reason is that the electronic part seems to go haywire on the b6d/t management systems. It may not be that way on the BP though.
                            Oh and with some experiments the BP likes the IAC runs perfectly
                            Festiver
                            93 L find/5 speed
                            BP/g15mr swapped
                            89 festie
                            rustful
                            93 festie
                            advanced suspension
                            kai/skeeter camber
                            b3t/g15mr
                            • A very festiva based presents got a AEM wideband a fender roller and a spectre air filter looking forward to making use of everything
                              Festiver
                              93 L find/5 speed
                              BP/g15mr swapped
                              89 festie
                              rustful
                              93 festie
                              advanced suspension
                              kai/skeeter camber
                              b3t/g15mr
                              • Grats! Tuned in to this thread
