4GREEN GRAB BAG
  • Originally posted by 1990new View Post
    Part Number on these?
    EDIT: NVM found them.
    • For everyone else the part number for the green lock surrounds VESSEL-IN.,LOCK is KKY026842104.
      • This is the proper latch for the cargo light correct?
        • No. That one does not have the rod to open the hatch, only has the rod to lock/unlock. But F3BZ says the wire will transfer to your stock latch and make it work perfectly. I would have to believe him since I made a similar mod to my factory one using a Capri latch.
          -Bryant
          • Anyone know the part numbers for the clear corners?
            All I could find was the Combo ones that have the turn signals built into them.
            I may go with those if I can hook both the ones on the bumper up with the ones on these corners, even if it takes some wire splicing.
            • I need the rubber boot/dustcap that goes at the bottom of the gear shifter.
              Anyone have a part number?
              Sent from my Agora Quad Core using Tapatalk
              1988 MAZDA 121- B6T + G5MR SWAP IN PROGRESS.
              • I just used a piece of leatherette from a Nissan Pathfinder transfer case shifter. No charge at the junkyard.
                • Originally posted by moz View Post
                  It's currently the second part number on the group order spreadsheet.
                  • Originally posted by Gomez View Post
                    the one contact with the wire will screw right into place on a US latch. all the holes are there and even tapped for the screw. the other contact is riveted to the post but you can drill out the rivet and re-attach that contact to your US latch. here is a new US latch with cargo wiring close up you can see what i mean. the contact on the left just screws in. the contact on the right has a button rivet. the GOO between the copper contacts is just dielectric grease.
                    • ^ thats good to know since the new latch is pretty inexpensive and will be easy to adapt it to the old latch in the Festiva. Sweet!!!
                      -Bryant
                      • Does FourGreen no longer have the black plastic radio bezels? I tried 2 different part numbers (based on a pix of one from another member....there was some glare/glint on the bag's part number) and the search engine didn't find a match.....this despite the number that was obscured was either a "6" or an"8"???
                        88L - 'Twistiva' - 'The Fusion of Man and Machine'
                        88LX - 'Laztiza' - Future Resurrection Project
                        91L - 'Mistiva' - My Daughter's DD
                        93L - 'Vextiva' - Airport Car
                        • Originally posted by Twistiva View Post
                          You mean this?
                          • Twist , Torque has the good part , its pictured upside down , but its the correct part.
                            • Originally posted by TorqueEffect View Post
                              Yep, that's it! Thanks a million! :-)
                              Turns out that what I thought was either a "6" or an "8" turned out to be a "B".
                              Thanks again, TorqueEffect and PhoenixSHO!
                              • Brackets for the front bumper supports (at the corners).
