b6t at 16 psi!
  • #61
    Originally posted by Advancedynamix View Post
    The oil drain from the turbo tends to get rock hard and brittle with age. Be careful with what you replace that hose with. I used a pre formed heater hose that I cut to fit. I found it by rooting through the coolant hoses at pep boys. I was skeptical about using heater hose for oil, but it held up for 2 years before I found a good factory replacement. I think I wrote down the part number for that hose somewhere, I'll look for it.
    If the hose is kinked at all it will back up and you'll burn oil.
    it's out there. but considering the price. wow.
    Mercury Capri XR2 IHI Turbo Charger Oil Drain Hose / Capri XR2 IHI Turbo Charger Oil Drain Hose / Mercury  Capri XR2 IHI Turbo Charger Oil Return Hose / Capri XR2 IHI Turbo Charger Oil Return Hose - NEW. This Mercury Capri XR2 IHI Turbo Charger Oil Drain Hose / Capri XR2 IHI Turbo Charger Oil Drain Hose / Mercury  Capri XR2 IHI Turbo Charger Oil Return Hose / Capri XR2 IHI Turbo Charger Oil Return Hose mates perfectly to the stock IHI VJ14, Turbo Charger Unit. The original Ford part number for this  Mercury Capri XR2 IHI Turbo Charger Oil Drain Hose / Capri XR2 IHI Turbo Charger Oil Drain Hose / Mercury  Capri XR2 IHI Turbo Charger Oil Return Hose / Capri XR2 IHI Turbo Charger Oil Return Hose is no longer active in the Ford parts database.
    Application: All Mercury Capri XR2 / turbo models: 1991, 1992 1993, 1994 - Mercury Capri XR2 IHI Turbo Charger Oil Drain Hose / Capri XR2 IHI Turbo Charger Oil Drain Hose / Mercury  Capri XR2 IHI Turbo Charger Oil Return Hose / Capri XR2 IHI Turbo Charger Oil Return Hose: 1991 / 91Mercury Capri XR2 IHI Turbo Charger Oil Drain Hose / Capri XR2 IHI Turbo Charger Oil Drain Hose / Mercury  Capri XR2 IHI Turbo Charger Oil Return Hose / Capri XR2 IHI Turbo Charger Oil Return Hose, 1992 / 92 Mercury Capri XR2 IHI Turbo Charger Oil Drain Hose / Capri XR2 IHI Turbo Charger Oil Drain Hose / Mercury  Capri XR2 IHI Turbo Charger Oil Return Hose / Capri XR2 IHI Turbo Charger Oil Return Hose, 1993 / 93 Mercury Capri XR2 IHI Turbo Charger Oil Drain Hose / Capri XR2 IHI Turbo Charger Oil Drain Hose / Mercury  Capri XR2 IHI Turbo Charger Oil Return Hose / Capri XR2 IHI Turbo Charger Oil Return Hose, 1994 / 94 Mercury Capri XR2 IHI Turbo Charger Oil Drain Hose / Capri XR2 IHI Turbo Charger Oil Drain Hose / Mercury  Capri XR2 IHI Turbo Charger Oil Return Hose / Capri XR2 IHI Turbo Charger Oil Return Hose
    (*) PLEASE NOTE: This Mercury Capri XR2 IHI Turbo Charger Oil Drain Hose / Capri XR2 IHI Turbo Charger Oil Drain Hose / Mercury  Capri XR2 IHI Turbo Charger Oil Return Hose / Capri XR2 IHI Turbo Charger Oil Return Hose is a special warehouse item, so please allow approximately an additional 3-5 business days from order date for item to ship. "All Sales Are Final" & "As Is"
    Please browse the entire Modern Capri Parts catalog for all your 1991 mercury capri, 1992 mercury capri engine parts, 1993 mercury capri engine parts, 1994 mercury capri engine parts needs
    • #62
      Could see if Russ sells them.
      91GL BP/F3A with boost
      • #63
        There it is, $22.50
        • #64
          THANKS!
          19?? 150$ burnout car SOLD
          1991 (STRESS RELIEF)SOLD
